Unable to make many concurrent SDE connections using arcpy
741
10-10-2019 12:35 PM
mohammednabil
I am try to make concurrent connections to the my SQL Server SDE using arcpy and multiprocessing libraries
When the number of working is large i.e. 16 , I got this error:
ERROR 000229: Cannot open GeoDB.sde/GeoDB.dbo.Layer1
while the code works fine if I am using small number of workers i.e. 4 or just without multiprocessing
Here is the simple code that successfully run without multiprocessing
arcpy.MakeFeatureLayer_management("GeoDB.sde/GeoDB.dbo.Layer1", "mylayer","status = 1")
here is the code with multiprocessing
def exe_task(layer_name):
      arcpy.MakeFeatureLayer_management("GeoDB.sde/GeoDB.dbo.Layer1", layer_name,"status = 1")
      return True
from multiprocessing import Pool
import arcpy
if __name__ == "__main__":
      number_of_workers = 4
      p = Pool(number_of_workers)
      tasks = ["layer1","layer2","layer3","layer4"]
      result = p.map(exe_task, tasks)
      p.close()
      p.join()
      print(result)
This is just a sample code to show the problem, if the number of workers 4 it works fine, if it is large like 16 it gives the error above. (also you need to increase the tasks number equal to workers numbers)
is there any configuration on arcpy or sde to fix this problem?
