Unable to access ArcGIS Server via .ags from stand-alone script
920
07-01-2025 03:54 AM
Yanu
Hey,
when I am using .ags file with ArcGIS Pro I can e.g. run this function via Notebook/PythonWindow:
https://pro.arcgis.com/en/pro-app/latest/arcpy/functions/listdatastoreitems.htm
However, when I am running standalone script, I am receiving:
RuntimeError: Cannot open AGS Server connection.
This is stand-alone AGS server.
Any ideas?
Regards,
Yanu
JoshuaBixby
MVP Esteemed Contributor
How are you running the script exactly?  Is it running from the same machine with the same user credentials?
Yanu
Exactly the same user, there is no issue with the license. I guess ArcGISPro is setting some additional params...
HaydenWelch
MVP Regular Contributor
Seems like you've got some sort of error in how you're passing the connection file to the function. You're using the correct environment since the error is related to the AGS connection and not the arcpy import, but the connection is failing in the standalone. Mind sharing the ListDataStoreItems call that's failing?
Yanu
My code is
import arcpy
ags_file = 'path_tofile.ags'
print(arcpy.ListDataStoreItems(ags_file, "DATABASE"))
