TypeError: GPToolDialog() takes at most 1 argument (2 given)
11169
21
08-04-2014 11:00 AM
SurendranNeelakantan
I am using ArcGIS 10.22
An error  is coming in the python window  "TypeError: GPToolDialog() takes at most 1 argument (2 given)"
But the tool seems working fine
The  documentation says : GPToolDialog(toolbox, tool_name)
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Does anyone know the  reason ?
Thanks
JasonScheirer
Esri Alum
Is the tool dialog showing up? If not, are you sure you're passing in the correct path to the TBX and the correct Tool Name?
DanPatterson_Retired
Is it in the format of the last line of that help?
pythonaddins.GPToolDialog(r'C:\MyTools\WaterStudy.tbx', 'GroundWaterYield'
note the raw notation to the tbx name.
Jason & Dan
Thanks for the reply
Yes Tool Dialog is showing up and executing .
I am using the  following line
pythonaddins.GPToolDialog(toolboxPath, toolName)
Where toolbox path and toolbox name are variable pointing to the correct path.
My question is  Why the error says  "at most 1 argument"  where it supports  2 arguments.
thank you
No clue...other people haven't reported errors
https://community.esri.com/message/392058?sr=search&searchId=4b22ed49-a83c-4de1-be96-7e8db45afe9c&se...
show us the path and toolbox name...however, I doubt that is the problem since you said the tool operates.
What version are you using?  I can find no bugs listed except for version 10.2.2 being modal
Dan
I am using 10.22
Here is the  code to call the Dialog
import arcpy
import pythonaddins
import os.path
class ButtonBuildGDB(object):
    def __init__(self):
        self.enabled = True
        self.checked = False
    def onClick(self):
        toolboxName = "GDBAutomation_DRAFT"
        toolName = "BuildGDB"
        toolboxPath = os.path.join(os.path.dirname(__file__), toolboxName + ".pyt")
Thanks
KenBuja
MVP Esteemed Contributor
Does the toolboxPath variable contain any spaces?
Ken
There is no spaces in the toolboxPath variable
Thanks
Surendran
From the thread I posted, I notice that they are using a toolbox (ie *.tbx)
toolPath = relPath + r"\Custom Tools\Get IR Count\Install\GetIR.tbx"
and you are using a python toolbox
could that be the difference?  You might be advised to consult the section on python toolboxes again since their behaviours differ in some respects.
Dan
I am not sure  if the python toolbox  is the problem.   I am  calling   tool from a python toolbox . Tool works fine from  tool bar button. The above error message is only visible if python window is open in Arcmap.  This error not preventing the tool execution. May be I can Ignore this.
Thank you
