TypeError: 'geoprocessing messages object' object is not subscriptable
2865
8
07-03-2024 06:09 AM
Glasnoct
def getParameterInfo(self) -> list:
        """Define the tool parameters."""
        project_id = \
            arcpy.Parameter(
                name="project ID",
                displayName="project ID",
                datatype="GPString",
                parameterType="Required",  # Required|Optional|Derived
                direction="Input",  # Input|Output
        project_id.filter.type = "ValueList"
        project_id.filter.list = self.project_ids
        return [project_id]
project_id = parameters[0].value
GetParameterInfo is returning [project_id] so I'm not sure why I can't subscript it . 'Parameters' without an index doesn't work either, so I'm not sure what the value method is expecting. This is pretty typical python tool code. Why is it a messages object to begin with? Is that just how the parameters function spits out the parameters?
Luke_Pinner
MVP Regular Contributor
I'd try changing "messages=None" to just "messages" as per all the official arcpy examples. Shouldn't make a difference, but ArcGIS does do some weird things with python toolboxes.
And make sure you are running it as a tool (from the toolbox or in code via arcpy.ImportToolbox) and not treating it as a regular python class and trying to instantiate it yourself.
I also see from your other post you were using an "@staticmethod" decorator for the execute method. Again, probably better to stick to the syntax shown by Esri in the examples (undecorated methods).
Luke_Pinner
Can you include more of the code where you call "project_id = parameters[0].value".
If it's in the execute method, you may have your arguments in the wrong order and are accessing the messages argument instead of the parameters argument.
Glasnoct
# db.project_ids is just a list of strings
        project_id = \
            arcpy.Parameter(
                name="project ID",
        project_ids = db.project_ids
        project_id.filter.list = project_ids
        return [project_id]
Luke_Pinner
You've already shown how you define the "project_id" parameter.  That wasn't what I asked to see.  Please include the code where you use/access that parameter.
Glasnoct
    def execute(self, parameters, messages=None):
        """The source code of the tool."""
        all_project_features_to_new_filtered_lyrs(project_id)
        return
Right, Monday mornings am I right? The access is in the error message in the original post. The full function isn't much longer.
This is more or less modeled directly off the suggested code I received in my last thread about parameter issues. https://community.esri.com/t5/python-questions/struggling-with-python-toolbox-tools-and-parameter/m-...
Luke_Pinner
Glasnoct
It was the @staticmethod decorator. It's been too long to remember why it was there; might've been an artifact from the github example I originally was imitating. Messages=None caused no issues.
Luke_Pinner
For next time, I suggest you include all relevant code in your post to start with. You're more likely to get an answer at all/quicker.
Luke_Pinner
Yes the "@staticmethod" decorator is definitely the problem.
The reason you got a TypeError: 'geoprocessing messages object' object is not subscriptable exception is that staticmethods don't get passed a reference to the instance of the class (i.e. "self")
So because you put a "self" argument in the definition of static method, when the method was called by ArcGIS, that first "self" argument got the parameters list, the 2nd "parameters" argument got the messages object and the "method" argument didn't get passed anything at all.  And because you had "messages" default to "None", you didn't get a more obvious error earlier - something like TypeError: Tool.execute() missing 1 required positional argument: 'messages'
Here's a simple tutorial:
Tutorials Teacher - staticmethod decorator
