Trouble Calculating a Field
7695
10
12-11-2014 09:29 AM
MarkAccettulla
I don't know a whole lot about python and scripting, so I was hoping somebody could give me a couple pointers on fixing some python.  I am trying to calculate a "final results" attribute field.  The field type is numeric, because I want the values to either be a 1 (pass) or 0 (fail).  I have attached 2 variations of the code I have tried, but they both give me errors.  The two fields I am trying to calculate from are both text fields, and the values for both are either "PASS" or "FAIL."
I know that this should be a simple task, but like I said I am very very new to python.  Any help or pointers would be much appreciated.
MarkAccettulla
Greg,
Thank you, this method also worked
