trim line to specified length
6417
11-16-2016 07:45 AM
KeithD1
Looking for suggestions on trimming polyline features to a specified length starting at a specified distance from the start of the tine. Both values are provided as feature attributes. The resulting features should be perfectly coincident with the original ones, just one end will be removed. Seems like there should be a pre-installed tool for this...am I missing something?
I'll be automating the resulting process (ArcPy?) running on ArcMap 10.1 (soon 10.4) with an Advanced license, in case that opens up any additional possibilities.
Thanks!
Tags (3)
JoshuaBixby
MVP Esteemed Contributor
Check the ArcPy Polyline documentation (10.4.x)segmentAlongLine().
JoshuaBixby
KeithD1
Thanks Joshua. This looks powerful enough to justify waiting for the 10.4 deployment at my workplace.
If anyone else is reading this, I would still be interested in a 10.1 based solution.
XanderBakker
Esri Esteemed Contributor
Hi Keith D ,
If I´m correct in 10.1 you have access to the cursors in the data access module and also the polyline::positionAlongLine method. In that case you could do something like:
# Name:        getSegmentAlongLine.py
# Purpose:
# Author:      XBAKKER
# Created:     16/11/2016
import arcpy
def main():
    fc = r'D:\Xander\GeoNet\GetSegmentAlongLine\gdb\data.gdb\myPolylines'
    fld_start = 'StartValue'
    fld_end = 'EndValue'
    fc_out = r'D:\Xander\GeoNet\GetSegmentAlongLine\gdb\data.gdb\result'
    lst_feats = []
    flds = ('SHAPE@', fld_start, fld_end)
    with arcpy.da.SearchCursor(fc, flds) as curs:
        for row in curs:
            polyline = row[0]
            start_m = row[1]
            end_m = row[2]
            # create segment along the polyline
            segment = getSegmentAlongLine(polyline, start_m, end_m)
            lst_feats.append(segment)
    arcpy.CopyFeatures_management(lst_feats, fc_out)
def getSegmentAlongLine(polyline, start_m, end_m):
    ''' get a segment along the line (ArcGIS 10.1)
        cut is not available nor is SegmentAlongLine
        polyline needs to be projected!
        polyline: the input polyline
        start_m: start measurement (m)
        end_m: end measurement (m)
    sr = polyline.spatialReference
    length = polyline.length
    # correct measurement values
    if start_m < 0:
        start_m = 0
    if end_m > length:
        end_m = length
    if start_m > end_m:
        start_m, end_m = end_m, start_m
    # define case
    if start_m == end_m:
        return None
    elif start_m == 0 and end_m == length:
        return polyline
    else:
        # get segment along the line
        lst_points = []
        len_acum = 0
        pnt_prev = None
        m = 0
        for part in polyline:
            for pnt in part:
                if pnt_prev == None:
                    pnt_prev = pnt
                # calculate distance between current point and previous one
                dist = getDist2Points(pnt_prev, pnt, sr)
                m_prev = m
                m += dist
                if in_range(start_m, m_prev, m):
                    # start point is between current and previous point
                    pnt_s = getPointBasedOnRelativePosition(pnt_prev, pnt, sr,
                                                            start_m, m_prev, m)
                    if pnt_s:
                        lst_points.append(pnt_s.firstPoint)
                if in_range_or_equal(m, start_m, end_m):
                    # point needs to be added to the list
                    lst_points.append(pnt)
                if in_range(end_m, m_prev, m):
                    # end point is between current and previous point
                    pnt_e = getPointBasedOnRelativePosition(pnt_prev, pnt, sr,
                                                            end_m, m_prev, m)
                    if pnt_e:
                        lst_points.append(pnt_e.firstPoint)
                pnt_prev = pnt
        segment = arcpy.Polyline(arcpy.Array(lst_points), sr)
        return segment
def getDist2Points(pnt1, pnt2, sr):
    try:
        pntg1 = arcpy.PointGeometry(pnt1, sr)
        pntg2 = arcpy.PointGeometry(pnt2, sr)
        dist = pntg1.distanceTo(pntg2)
        return dist
    except Exception as e:
        print 'ERR getDist2Points', e
        return 0
def in_range(value, minimum, maximum):
    return value > minimum and value < maximum
def in_range_or_equal(value, minimum, maximum):
    return value >= minimum and value <= maximum
def getPointBasedOnRelativePosition(pnt_from, pnt_to, sr, m_pnt, m_from, m_to):
    try:
        # create line from two points
        line = arcpy.Polyline(arcpy.Array([pnt_from, pnt_to]), sr)
        # get relative position for m value on line
        position = (m_pnt - m_from) / (m_to - m_from)
        # return point based on relative position
        return line.positionAlongLine(position, True)
        print 'ERR getPointBasedOnRelativePosition', e
        return None
if __name__ == '__main__':
    main()
Test results:
  • in black the input polylines and indicating with the black labels the OBJECTID of the input features
  • in green the resulting lines (indicating the direction too)
Based on a featureclass with this attribute table:
KeithD1
Thanks for the detailed and thorough response, Xander!
XanderBakker
You're welcome desertsp , however the recommendation remains... it is better to update to a more recent version.
