Tooltip content for fields of script tool
1299
05-28-2024 05:40 AM
ShareUser
Esri Community Manager
I created a script tool that takes select dimensions from n+1 .kml files and generates a fairly simple point feature class.* Everything functions as intended, but I am unable to figure out how to add content to the tooltips for each field (no descriptive text appears when a user hovers over the "i" next to a field):
For what it's worth, I am using 3.2.
- Can this be done in the script itself? If so, what's the play?
- If this is to be done through the user interface, where do I go? I can't find anything in parameters, and I don't see anything field specific when I right click the script to edit the meta data.
- Another method?
Thanks for your time!
*tool allows you to transform .kml exports from adsbexchange into a 2d point layer. Retains n-number, timestamp, and altitude as contextual fields while only symbolizing the point with latitude and longitude.
AlfredBaldenweck
MVP Frequent Contributor
The tooltips are set through the script's metadata (right-click, edit metadata).
I think there's an Idea floating around to let us do that stuff from within the tool itself (at least with Python Toolboxes) but I'm not sure where it is.
AlfredBaldenweck
ShareUser
Hey - thanks for your response. Unfortunately Syntax is not available for me when I edit my script's metadata.
Can you confirm for me which metadata style you have selected (Options -> Metadata -> Metadata Style)? I'm hoping this might do the trick, but I have tried all of those available to me (screenshot), but none have the option in the screenshot you posts.
AlfredBaldenweck
I know you marked this as a solution, but I generally just use the “Item Description” option. Not sure about the other styles.
