The intersection of two polygons
2791
11-17-2012 04:56 PM
XintaoLiu
Now I have two shapes of polygons, how to get the intersection area of them?
I tried: interShp = Shp1.intersection(shp2), but it does not work.
Thanks in advance.
MikeHunter
What you are trying to do will work with arcpy 10.0 or 10.1.  But you are calling the geometry object method wrong:
 interShp = Shp1.intersect(shp2, 4)
Not "intersection, but "intersect."  And you need the 2nd arg, the dimension of the output geometry.  You said area, so that would be 4.
good luck
Mike
T__WayneWhitley
Honored Contributor
You can use geometry objects with the Intersect tool, see this:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//002z0000001z000000
In your case as you've described it, you would create 2 objects to enter as input, potentially writing a 3rd geom object or write the output to a new shapefile or fc.
MikeHunter
good luck
Mike
XintaoLiu
good luck
Mike
Thank you so muck! It works!
By the way, where can I find such specific reference and examples to read? Thank you again.
T__WayneWhitley
Honored Contributor
I am not using 10.1 yet but found the method, intersect(other, dimension), documented here:
http://resources.arcgis.com/en/help/main/10.1/index.html#//018z00000061000000
Thanks Mike, I was unaware of this and although I couldn't find the specific doc for 10.0, I will try this out tomorrow.
