TextElement with arcpy.mapping.ExportToJPEG
1542
01-07-2019 03:36 AM
MicheleDe_Santis
Hi to all,
I'm using arcpy to export map in JPEG format. I am not able to get the TextElement in the output file. The label "Confini comunali" doesn't appear in the JPEG file. Even if I don't change TextElement.text, it doesn't work.
Can anyone help me?
Thank you,
 Michele
 PS Using ArcMap 10.1 on Windows 10, Python 32-bit.
The portion of my script is:
mxd = arcpy.mapping.MapDocument(r"C:\StampeGriglie\Comuni.mxd")
df = arcpy.mapping.ListDataFrames(mxd)[0]
# Change text element
TextElement = arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT", "MioTesto")[0]
TextElement.text = "Confini comunali"
path_output = "C:/StampeGriglie/Output/1234.jpg"
arcpy.mapping.ExportToJPEG(mxd, path_output, df,
                           df_export_width=9360,
                           df_export_height=6623,
                           resolution=200,
                           world_file=False)
del mxd
RandyBurton
Although I am not running 10.1, I did some experimenting and have the following suggestion:
arcpy.mapping.ExportToJPEG(mxd, path_output, "PAGE_LAYOUT",
                           resolution=200,
                           world_file=False)
I am assuming the text element was created in layout view.  Referencing "df" in the export would point to the first data frame and not the layout view.
MicheleDe_Santis
Hi Randy,
excuse me for the delay. You are right. I had to change dinamically the
TextElement, then I had to save mxd and now ExportToJPEG using
"PAGE_LAYOUT". It works.
Michele
Il 8 gennaio 2019 alle 4.47 Randy Burton <[email protected]> ha scritto:
GeoNet <https://community.esri.com/?et=watches.email.thread>
Re: TextElement with arcpy.mapping.ExportToJPEG
reply from Randy Burton
<https://community.esri.com/people/rvburton?et=watches.email.thread> in
Python - View the full discussion
<https://community.esri.com/message/823200-re-textelement-with-arcpymappingexporttojpeg?commentID=823200&et=watches.email.thread#comment-823200>
