Terminating a multiprocessing pool gracefully in a toolbox tool
1119
10-21-2019 09:08 AM
JonathonHurley
ArcCatalog 10.6
I made a toolbox script that uses multiprocessing. The tool runs fine if left to complete but if the cancelled button is pressed I can't get it terminate the pool. I am fairly new to python and arcpy, but I did find the env.autoCancelling and env.isCancelled and have tried that but not very successfully.
simplified example (not actual code)
import multiprocessing
import arcpy
arcpy.env.autoCancelling = False
NUM_FINISHED = 0
FINISHED = False
def on_complete(results)
   global NUM_FINISHED
   global FINISHED
   if results:
      NUM_FINISHED += 1
      if NUM_FINISHED == 10
         FINISHED = True
def check_processes(pool)
   global FINISHED
    while True:
         time.sleep(10)
         if arcpy.env.isCancelled:
               pool.terminate()
         if FINISHED:
               return
def processes_stuff()
   ''' do stuff here'''
def main(peram_one, peram_two)
   pool = multiprocessing.pool(10)
   for i in range(10):
      pool.apply_async(process_stuff, args=(peram_one, peram_two), callback=on_complete)
      pool.close()
if __name__=='__main__':
   in_feature = arcpy.GetPerameterAsText(0)
   to_buffer = arcpy.GetPerameter(1)
   main(in_feature, to_buffer)
   arcpy.SetPerameterasText(2, in_feature)
When the cancel button is pressed, the processes are sill running and never cancel and the cpu stays at 100% even though they become completely detached from ArcCatalog and the GUI from ArcCatalog shows that it was cancelled. What am I missing?
