Task with Dictionary
5299
12
05-05-2017 01:11 AM
JohnMcoy
Could you explain me, how to change field value with dictionaries?
for example :
dict = {"A" : "A-150",
            "B" : "B-200",
            "C" : "C-250"}
And i want change A with A-150, B with B-200
Thanks !
JohnMcoy
It has to be a piece of that script. You see like this part(code) if any row hasn`t a value, in CSV will write Null.
for n,i in enumerate(row):
                    if i==None:
                         row[n]="NULL"
So I think I need only a couple lines of code to reach a goal.
Now I have this:
for key, value in dict.items()
                row[1]=value
DanPatterson_Retired
you still need the def example and you call it
if i is None:
    row = "NULL"
else:
    row = get_val(i)  # get)val is the def and it needs your dictionary
BlakeTerhune
If there's no extra logic involved with getting the value, why not just look it up in the dictionary immediately instead of making a separate function?
dict = {
    "A": "A-150",
    "B": "B-200",
    "C": "C-250"
for n, i in enumerate(row):
    if i:
        row[n] = dict[i]
    else:
        row[n] = None‍‍‍‍‍‍‍‍‍‍‍
Keep in mind that you will get a KeyError and the script will stop if i is not in the dictionary. You can use dict.get() and specify a default value if you want it to keep running.
