Take values from one field, and concatenate into string field if IDs are the same.
2131
07-20-2022 02:56 PM
Server
Fairly new to python. By no means a beginner, but I still have trouble with logic.
I'm currently trying to create a script which takes an ID field - if the IDs match up, then take the value from a name field, and concatenate together into a list, and fill out a concatenated list field (see table)
I know i will have to use a update_cursor and a counter etc. the logic for whatever reason is escaping me on how to assemble the python.
ID
Name
Name_cancat
33
hello
Hello, hi, bye
33
hi
Hello, hi, bye
33
bye
Hello, hi, bye
44
red
Red, tan, blue
44
tan
Red, tan, blue
44
blue
Red, tan, blue
88
dog
Dog, cat
88
cat
Dog, cat
I know it will be something like this (obviously missing a ton of code/logic)
with arcpy.da.UpdateCursor("FC", ['ID', 'name', 'name_concat']) as cursor:
       myList = []
       for row in cursor:
              myList.append(row[1])
       row[2] = myList
       cursor.updateRow(row)
   any help pointing me to a resource would be greatly appreciated!
JohannesLindner
Python:
# use a SearchCursor to get ids and names
ids_and_names = [row for row in arcpy.da.SearchCursor("FC", ["ID", "name"])]
# use an UpdateCursor to update the concatenated names
with arcpy.da.UpdateCursor("FC", ["ID", "name_concat"]) as cursor:
    for row in cursor:
        names = [name for id, name in ids_and_names if id == row[0]]
        name_concat = ", ".join(names)
        cursor.updateRow([row[0], name_concat])
You could also use the field calulator with Arcade:
// filter the dataset by the current id
var id = $feature.ID
var features_with_this_id = Filter($featureset, "ID = @ID")
// extract names as array
var names = []
for(var f in features_with_this_id) {
    Push(names, f.name)
// return the concatenated array
return Concatenate(names, ", ")
Have a great day!
Johannes
DonMorrison1
 I would make 2 passes through the table.
On pass one use a search cursor to create a python dict with each entry having the ID as the key and the list of string to be concatenated as the value.
On the second pass use an update cursor to  populate the name_cancat field in each record by using the value of the ID field to get the concatenated string from the dict.
curtvprice
How about the Merge tool with a field map with a "," delimiter to combine the values, then a Join Field (Maybe faster for a large dataset.)
JohannesLindner
Python:
    for row in cursor:
var names = []
    Push(names, f.name)
Have a great day!
Johannes
Server
this is exactly what I needed! Thank you!
