TableToExcel - Loop
11062
28
06-13-2017 01:24 PM
DougHaller1
Hi GeoNet and thanks in advance. I'm new to Python.
My goal is to write a script that converts all the shapefiles in a gdb into a csv (although I will take an Excel spreadsheet, too).  I plan to convert the final program into a script tool with parameters for which gdb to access and where to save the spreadsheets. I can get a single shapefile to convert into an Excel spreadsheet. I would like to loop through the gdb and convert each shapefile to a unique csv (for this case, let's assume that the gdb contains only shapefiles).
My code fails and I have received a couple of different error messages depending on the variable I use for the in_table argument (hope I have that right).
I suspect that I am not correctly naming my in_table and out_xls variables.
Here's a screen shot of my code. Sorry for the small size, not sure how to enlarge the text.
tabletoexcel loop
curtvprice
What is getOutput?
.getOutput is a method called on a result object. This is the most direct way to get the result value from GetCount (or any other tool that returns a result.) The result is a string, so that's why he wrapped it with int() -- to convert '45' to 45 for a count of 45 rows.
FC_Basson
Yes just change the workspace and output folder on your side.
DougHaller1
Thanks FC.
Question:
This part of your code (below) looks like a parameter in a script tool. Do I need to create a script tool and designate this as a parameter? If so, I think it should be an output. What data type is it considered.  Thanks again.
.getOutput(0))
BlakeTerhune
Curtis Price‌ already answered this for you above...
DougHaller1
Thanks for the reminder.
DougHaller1
Thanks FC!
Your code works for me. I need to take it a few steps further to create a script tool for my specific needs.  Much appreciated.
BlakeTerhune
Glad you found a solution! Don't forget to Mark a reply as the Correct Answer.
curtvprice
Excel files are limited to 65535 rows:
This is true for .xls format, but not .xlsx.
Understanding how to use Microsoft Excel files in ArcGIS—Help | ArcGIS Desktop
DougHaller1
THANKS ALL. I will review each of the replies in detail and try each suggestion.
Doug
