Table to Excel
2780
8
06-18-2014 07:38 AM
JohnByrne
I am currently trying to use the Table to Excel script to produce a table of a query that I have created. It returns all the fields not just the selected one. Any ideas? I am sure it is simple
Thanks
John
JoshuaChisholm
Hello John,
As far as I understand it, the Table To Excel tool will export selected records (not selected fields) to an excel table. If you only want selected field in the excel table, I think you would have to use the Make Table View tool before the Table To Excel tool. You could use the "field_info" parameter to pick out your desired fields.
Hope that helps!
JohnByrne
Hi Joshua,
Thanks for replying, that certainly looks promising. I am actually trying to export the table based on a query I have already ran and linked to Data Driven Pages. How would I refernce that in the Make Table View? I am new to this so please excuse the silly question.
I have linked my current attempt at the script, which works for the initial part of what I am trying to achieve, just failing at the output.
I have attached my script so you can maybe see it easier.
Thanks
JoshuaChisholm
Try this:
def table_to_excel(in_table, output, use_field_alias=False, use_domain_desc=False):
    desiredFields=["Field1","Field3","Field8"] #desired fields for excel output
    # Get the fields from the input
    fields= arcpy.ListFields(in_table)
    # Create a fieldinfo object
    fieldinfo = arcpy.FieldInfo()
    # Iterate through the fields and set them to fieldinfo
    for field in fields:
        if field in desiredFields:
            fieldinfo.addField(field.name, field.name, "VISIBLE", "")
    # The created crime_view layer will have fields as set in fieldinfo object
    arcpy.MakeTableView_management(in_table, "table_view", "", "", fieldinfo)
    # To persist the layer on disk make a copy of the view
    arcpy.TableToExcel_conversion("table_view", output)
Note that I couldn't fully test it because I'm still on 10.1.
Let me know if it works!
JohnByrne
It seems to work, unfortunately I don't know how to define the output
JohnByrne
This a view of the amended code, as per your advice
import arcpy
import os
import sys
import xlwt
import datetime
mxd=arcpy.mapping.MapDocument("current")
BUSID_TEMP=arcpy.GetParameterAsText(0)
LayersDF=arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
selLyr=arcpy.mapping.ListLayers(mxd, "FP_sample", LayersDF)[0]
for elm in arcpy.mapping.ListLayoutElements(mxd):
    if elm.name=="GridTable": GridTable = elm
ddp=mxd.dataDrivenPages
arcpy.AddMessage(BUSID_TEMP)
pageID=mxd.dataDrivenPages.getPageIDFromName(str(BUSID_TEMP))
mxd.dataDrivenPages.currentPageID=pageID
#excel export part of the script
def table_to_excel(FP_sample, output, use_field_alias=False, use_domain_desc=False):
    desiredFields=["Field1","Field3","Field4"] #desired fields for excel output
    # The created view layer will have fields as set in fieldinfo object
    arcpy.MakeTableView_management(FP_sample, "table_view", "", "", fieldinfo)
    arcpy.TableToExcel_conversion("table_view", pop.xls)
JoshuaChisholm
Hello John,
I'm sorry if I was unclear, but I have some corrections for your script:
  1. In the line desiredFields=["Field1","Field3","Field4"], you should specify the fields by their name (not their position or alias). This line should be something more like desiredFields=["CityName","Pop","Province"] or whatever fields you want to include. I'm sorry I was unclear on that line.
  2. In the script you posted (TableToExcelJB.py), the defined method "table_to_excel" takes 2 inputs ("in_table", "output") and 2 optional inputs ("use_field_alias", "use_domain_desc"). This is all stated in the line def table_to_excel(in_table, output, use_field_alias=False, use_domain_desc=False):
  3. This defined method is called (and run) from this line (at the bottom of the script): table_to_excel(arcpy.GetParameterAsText(0),arcpy.GetParameterAsText(1),arcpy.GetParameter(2),arcpy.GetParameter(3)).
    This means the output is being defined by the user in a tool. If you want to 'hardcode' the output location, specify it like this:
    output=r"C:\Path\To\pop.xls"
  4. In further looking at the script (TableToExcelJB.py) you provided, it looks like it was designed to handle your data is a special way, reformatting some data as it runs. I'm worried a more spimlified version of this script (as I provided) will not handle your data in the same way the TableToExcelJB.py script does. Is this a problem?
DanPatterson_Retired
Just a thought, if the table is in ArcMap and you hide the fields you don't want, then export the file...do you get the results you want?  If you are working with a file on disk, all fields will get exported
JohnByrne
Hi Dan,
I am going to have a play with your advice now. Essentially my problems are (many but will simplify)
1. I need to create datadriven pages from a specific query, which I have managed to do at the minute.
2. The results of this query needs to be also shown in a seperate table hence why I am trying to export it to Excel. We have had a look at using Production mapping but there are too many varied results between queries to maintain a consistent look.
3. I am unsure, due to my inexperience if I should be changing the input and out when it appears in the script to get the results.
Hope that makes sense and thanks for your help
