syntaxError: EOL while scanning string literal
1668
02-07-2022 10:18 PM
abdullahAli91
Hi guys,
I am trying to make a new filter with makeFeatureLayer_management . it works fine in arcgis pro as standalone script but while running as a geoprocessing service it shows me an error :
  • esriJobMessageTypeError: File "<string>", line 31 arcpy.MakeFeatureLayer_management(CADSrs, CADlyr,g_ESRI_variable_3'") ^ SyntaxError: EOL while scanning string literal
the code snippet :
arcpy.MakeFeatureLayer_management(CADSrs, CADlyr,"\"Layer\" = 'karar'")
 My question is there any different way to make this filter with python "\"Layer\" = 'karar'"?
I've tried to add r before But it didn't works for me.
Thanks In advance
DanPatterson
MVP Esteemed Contributor
building the whereclause depends on the source of the data.
Try using AddFieldDelimiters
fc = r"C:\a_path\to\a\file_geodatabase.gdb\featureclass_name"
whereclause = """{} = 'bob'""".format(arcpy.AddFieldDelimiters(fc, 'Name_2'))
whereclause
"Name_2 = 'bob'"
the structure depends on the source
... sort of retired...
