Survey123 to Survey123 data append
126
3 weeks ago
AroldoRocha
Hello everyone!
I'm using ArcGIS Pro 3.4.5 and I'd like to know if anyone can give me some references, and even an example, of how I can append data from a Survey123 form (it contains some repeats) to another survey that basically has the same structure and attribute names - the difference is that the target survey will have some additional attributes, not present in the first one, and which will certainly be empty.
I think a challenge lies in preserving the Global-ids in the destination tables, to preserve the relationships of the repeats.
JamesTedrick
Esri Esteemed Contributor
Hi @AroldoRocha ,
I would recommend using the Append tool with the Preserve Global IDs option - https://doc.esri.com/en/arcgis-pro/latest/tool-reference/environment-settings/preserve-globalids.htm...
AroldoRocha
Thank you @JamesTedrick, I wasn't aware of that parameter.
