Survey123 to Survey123 data append
81
yesterday
AroldoRocha
Hello everyone!
I'm using ArcGIS Pro 3.4.5 and I'd like to know if anyone can give me some references, and even an example, of how I can append data from a Survey123 form (it contains some repeats) to another survey that basically has the same structure and attribute names - the difference is that the target survey will have some additional attributes, not present in the first one, and which will certainly be empty.
I think a challenge lies in preserving the Global-ids in the destination tables, to preserve the relationships of the repeats.
JamesTedrick
Esri Esteemed Contributor
Hi @AroldoRocha ,
I would recommend using the Append tool with the Preserve Global IDs option - https://doc.esri.com/en/arcgis-pro/latest/tool-reference/environment-settings/preserve-globalids.htm...
AroldoRocha
Thank you @JamesTedrick, I wasn't aware of that parameter.
