Survey Question for all Python Programmers. Please I need feedback from you all!!
2840
11
06-25-2013 12:59 PM
MichelleCouden1
OK, so I'm new at writing scripts. I take alot of pride in my work when I finish the script. So recently, one of my coworkers took one of my scripts and rewrote it to fit his needs. Should I be happy about this?????? I'm not used to people taking my work. Is that what we do with our scripts? Share them I guess??
DavidAllen
I generously share my code with anyone who wants it. And when I borrow code, I typically keep the "Author:" line at the top as the original author and add an "Amended by:" name and date, and depending on the severity of the change, a note on what changes were made.
People should be polite and respectful when they borrow your code, and you can request attribution. But I don't think it's a requirement.
DanPatterson_Retired
I do as well, particularly Python code.  If you don't want it used by others, then make sure you include a distribution license agreement.  Alternately, you can embed code within a toolbox which those people over the age of 16 unable to unlock your code 🙂
RhettZufelt
MVP Notable Contributor
I have no problem sharing my code.  besides, anyone I work with would need to come back to me to modify it for them anyway  :cool:
R_
JamesCrandall
I have no issue sharing -- it's not entirely my code to begin with.  My thought is that I am not really writting orginal, although I start from scratch, libraries so much as I am mostly re-organizing and invoking/implementing things that have already been developed into a logical configuration that solves my (or my user's) particular needs.
Take a "new" COM toolbar that I may build from scratch and delpoy it as an Extension: Really, I am just invoking all of the ArcObjects that make up ArcGIS --- I have not rebuilt a new ArcGIS, I am simply re-organizing things that solve a particular need that the default version of the software may not do well or efficient for a particular user or set of users.  Same with Python libraries and Geoprocessor objects I may develop.
MichelleCouden1
Thanks Guys!! I'm a very sharing person. And I feel my coworkers should know what I know. I think it was just the way he did it. After I got home, I started to feel glad he did use it. Because he won't learn just like I wouldn't learn if I didn't try.
ChrisSnyder
Honored Contributor
They say the biggest compliment a programmer can have is for someone to steal your code...
But that said, if I significantly borrow from someone elses code, I typically have a blurb in my header that indicates that.
However, if your coworker took all the credit and made it appear that he/she did all the work without putting your name in there... well that would make anyone mad!
ThomasLaxson
If it's a coworker, then you should be happy that your company/organization can now run a little bit more efficiently due to the code that you wrote. Just make sure that your superiors know who wrote the code when your next performance review rolls around.
JimCousins
Open source software like Python is designed to be developed by a collaborative effort, with sharing of libraries. No programmer will redevelop code that exists if it can be avoided,  but, as everyone else has indicated, proper credit should always be given. Simply look through the forums to see people sharing everything from snippets to complex algorithms and modules. Be satisfied that you have created something others appreciate and can use, but call anyone out who does not credit your portion of the work.
Regards,
Jim
ChristinaKellum
I wouldn't be where I am now if I didn't borrow code from you! I've learned a ton from you.  Thank you!
