Subtype Group Layers import via arcpy
577
07-30-2025 03:25 AM
MarianoDiNapoli
Hello everyone,
I need to import Utility Network layers into a map using arcpy, specifically with the Subtype Group Layers visualization.
It seems there is no built-in way to perform this type of import, so I would like to ask if anyone has any suggestions or knows of alternative methods to achieve the same result.
Thank you very much!
Mariano
TonyAlmeida
MVP Regular Contributor
Maybe try saving it as a layer file then importing it to the map (addDataFromPath)?
