Stripping Text in Field Calculator using wildcard
1616
7
01-24-2013 05:15 AM
NoahHuntington
Is there anyway to strip text using wild card...
As in:
HITCH ENTERPRISES, INC. WARRANTY DEED BOOK 552, PAGE 532 (NW/4) (NE/4) (SE/4)  OUT OF SECTION 29 TOWNSHIP 1N  RANGE 16E TEXAS COUNTY, OKLAHOMA
Would like to remove anything after "OUT "
Would like to use "Out " as wildcard for strip function instead of string position as table attributes vary?
Thanks in advance...
MathewCoyle
Honored Contributor
Something like this.
var = 'HITCH ENTERPRISES, INC. WARRANTY DEED BOOK 552, PAGE 532 (NW/4) (NE/4) (SE/4) OUT OF SECTION 29 TOWNSHIP 1N RANGE 16E TEXAS COUNTY, OKLAHOMA'
keepVar = var.split('OUT')[0]
NoahHuntington
Sort of.
I need something that will work for a variety of instances in a field which all contain "OUT OF " a varying positions in the text...
CLAWSON LAND PARTNERSHIP WARRANTY DEED BOOK 1069, PAGE 271 & BOOK 1061, PAGE 359 (E/2 OF NE/4) (SE/4)  OUT OF SECTION 15 TOWNSHIP 1N  RANGE 16E TEXAS COUNTY, OKLAHOMA
or
HITCH ENTERPRISES, INC. WARRANTY DEED BOOK 552, PAGE 532 (W/2 OF NW/4)  OUT OF SECTION 15 TOWNSHIP 1N  RANGE 16E TEXAS COUNTY, OKLAHOMA
Thanks for the response.
AndrewChapkowski
You can try this as well:
text = "HITCH ENTERPRISES, INC. WARRANTY DEED BOOK 552, PAGE 532 (NW/4) (NE/4) (SE/4) OUT OF SECTION 29 TOWNSHIP 1N RANGE 16E TEXAS COUNTY, OKLAHOMA"
loc = text.find("OUT OF") #"OUT" works the same
print text[:loc]
MathewCoyle
Honored Contributor
I'm confused. How does my example not work? You simply substitute var for whatever variable holds your field value.
NoahHuntington
print text[:loc]
This is good.  How would I rework this to work with all items in field?
Maybe something similar to:
def func():
text = !Label!
text.find("OUT OF")
print text[:loc]
AndrewChapkowski
I don't know what you mean by items in a field.
If you have a cursor you can do something like:
with da.SearchCursor(<data>, [fields]) as cursor:
   for row in cursor:
      fieldValue = row[cursor.fields.index("fieldname")]
      startWord = row[cursor.fields.index("startWordField")]
      stopWord = row[cursor.fields.index("stopWordField")]
      stop = fieldValue.find(stopWord)
      start = fieldValue.find(startWord)
      print fieldValue[start:stop]
I didn't test the code, but that's how you can break a string up by a start and stop position.
For help with working with python standard types, please see: http://docs.python.org/2/library/stdtypes.html
Thank you
NoahHuntington
You'll have to forgive me Matthew.  I am a little slow with all of this.  Would you be able to provide a screen cap of this used in field calculator?  I appreciate your input.
