String values in GetParameterAsText()
9038
11
01-03-2017 02:24 PM
JaredPilbeam1
I have a working ArcMap script tool called Update Map Elements that updates text and numbers in ArcMap documents.
It has four parameters; Workspace, Output, oldText and newText. Workspace is where the input folder goes. Output is the save-to folder. OldText is the text string to be replaced by the newText text string (Red Branch changes to Blue Branch).
My problem is: how can I have multiple string values? So, in the above parameters I specify the Red Branch string value to be replaced by Blue Branch. What if I wanted to have a bunch of string values--such as Red Branch, 600, Violet (oldText) and the corresponding newText values Blue Branch, 800, Green?
I have a feeling I add index positions to the values within the script, but I'm not sure how. I've had a look at this though I'm not sure it's the right approach: SetParameterAsText—Help | ArcGIS for Desktop
Here's the script behind the Update Map Elements tool:
#set path to relevant folder
import arcpy
from arcpy import env
import os
arcpy.env.overwriteOutput = True
# set path to relvant folder
arcpy.env.workspace = Workspace = arcpy.GetParameterAsText(0)
Output = arcpy.GetParameterAsText(1)
oldText = arcpy.GetParameterAsText(2)
newText = arcpy.GetParameterAsText(3)
# list the mxds of the workspace folder
for mxdname in arcpy.ListFiles("*.mxd"):
    print mxdname
# set the variable
    mxd = arcpy.mapping.MapDocument(Workspace + "\\" + mxdname)
# replace '2016' that occurs in the title of document
    for elm in arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT"):
        if oldText in elm.text:
            elm.text = elm.text.replace(oldText, newText)
            print '{} changed'.format(elm.text)
    for elm in arcpy.mapping.ListLayoutElements(mxd, ""):
        if oldText in mxd.title:
            mxd.title = elm.text.replace(oldText, newText)
# move the mxd.saveACopy outside of the if loop so a copy is saved even it does not meet the condition of the if loops
    mxd.saveACopy(os.path.join(Output + "\\" + mxdname))
# do not include this delete statement inside the above loop or it will delete the mxd object inside the loop. Make sure to dedent.
del mxd
Thanks in advance.
RebeccaStrauch__GISP
Make sure you open the post in a new tab when you reply.  If you are looking at it in the geonet inbox you will not see the option.
JaredPilbeam1
Thanks Rebecca. Here it is.
import arcpy
import os
oldList = oldText.split(', ')
newList = newText.split(', ')
    print mxdname
# set the variable
# replace elements that occur in the map document
        counter = 0
        for text in oldList:
            if text in elm.text:
                elm.text = elm.text.replace(text, newList[counter])
                counter = counter + 1
            else:
        counter = 0
            if text in mxd.title:
                mxd.title = elm.text.replace(text, newList[counter])
            else:
del mxd
