I got table field from the county and I just want to extract city from the addresses provided, I don't have any python background.
sample table field situs_addr:
123 street name, city state zip
45 street and street, city state zip
1000 street blvd, city name state zip
I successfully got the address number with street name separated using "split"
!situs_addr!.split(',')[0]but I'm having a hard time figuring out how to extract just the city, since the length of each addresses are different.
Thank you!
AS the city could be more than 1 word I might suggest splitting by a space, then takin the last but 2 entries:
(" ".join((!situs_addr!.split(',')[1]).split(" "))[:-2])
Lets say you have a variable called address
address = '123 street name, city state zip'
You are correctly splitting the string on the comma. When you do that, you get this
['123 street name', 'city state zip']
This gives you two items in a list. You want to grab the second item (index 1), and split again... but this time splitting on spaces. You will then grab the city on index 0 (state = index 1, zip = index 2).
address.split(', ')[1].split(' ')[0]
The result is the city
Situs_Addr.split(',')[1].split(' ')[0]
It didn't work.
!Situs_Addr!.split(',')[1].split(' ')[0]
Same, it didn't work.
Could you 'Check the Geoprocessing results window' for more details?
Are any of the records blank or missing the ","?
Yes, some rows are blank.
