Splitting String at ',' accounting for No Data
5880
23
01-10-2019 10:44 AM
deleted-user-qpvAI3Fo0MKR
I've got a table with a field named Maintenance Tasks. I would like to parse the values in this field into separate fields (Task1, Task2 etc.):
I can use:
         None if !MaintenanceTasks! == None else !MaintenanceTasks!.split(',')[0]
and this will parse the first item correctly into Task1, it also accounts for any null values in MaintenanceTasks.
The problem I'm running into is, for example, OID 23 above, when there's just a single item in the MaintenanceTasks field (ReplaceHead).
Any help would be greatly appreciated. FWIW I'll be scripting in Python.
Tags (1)
DanPatterson_Retired
I hate it when you forget to press Add Comment...
A bit late, but better than never
Josh... a few enumerate things
a = ['a', 'c', 'b', 'd']
for i in range(len(a)):
    print(i)
for i, j in enumerate(a):
    print("{}, {}".format(i, j))
0, a
1, c
2, b
3, d
list(enumerate(a))
[(0, 'a'), (1, 'c'), (2, 'b'), (3, 'd')]
# ---- no need to check the length of something, enumerate is smart
a = []
list(enumerate(a))
# ---- and they return the same thing, but 'enumerate' sounds cooler
    print(i)
for i in enumerate(a):
    print(i)
# ---- ps... they both returned nothing, but an empty list
JoeBorgione
I need to swap out range(len(someList)) with enumerate(someList) in a couple scripts to get a handle on it. To me, a list of tuples is something of a hybrid between a dictionary and an array...
JoshuaBixby
MVP Esteemed Contributor
If you are used to working with a counter variable to index positions in a list, you can use tuple unpacking in the for loop:
for i,v in enumerate(list):
    pass
Thank you very much, Dan.
If I understand your top example above, the location of the item in the list is being enumerated; location 0 = a, location 1=a and so on. Is this accurate?
In the latter example, both returned nothing as you declared a = [ ].
Very useful, thanks for the education!
