Split text field into two new fields?
34048
17
11-24-2010 08:51 AM
DavidMedeiros
I'm a GIS MA student looking for some help on creating a Python script in ArcGIS for a class project. I have a text table with several fields (Tenant Name; Address; Sq Ft; Destination). The destination column contains information that I want to separate into two new fields - one for the first word in the original column and one for the second word in the original column. I then need to write this new info back into the original table.
What ArcPy commands should I be looking at to accomplish this? Can anyone point me to a similar finished script?
David
DavidMedeiros
Ahh, I mistook last value for last whole word. Is there a modifier to the row.Type = row.Dest statement that can select the entire last word from the original row?
DavidMedeiros
Ok, I think I got it. Here's the script:
Script:
# split table script
#add field step
import arcpy
from arcpy import env
inputTable = arcpy.GetParameterAsText(0)
arcpy.AddMessage ("input " + inputTable)
#list fields (stops duplicate add fields)
theFieldList = arcpy.ListFields (inputTable, "Type")
arcpy.AddMessage ("the count" + str(len(theFieldList)))
#following exectues the add field
if len(theFieldList) == 0:
    arcpy.AddField_management(inputTable, "Type", "TEXT")
else:
    arcpy.AddMessage ("Field Exists")
#split field loop
rows = arcpy.UpdateCursor (inputTable)  #gets all vlaues for table
for row in rows:  #loops through vlaues and updates new field basedon last word of orig field
    row.Type = row.Dest.split(" ")[-1] if " " in row.Dest else ""
    rows.updateRow(row)
del row
del rows
resulting table has a new field "Type" with the second word from the "dest" row copied over. If no second word nothing is copied over. Thanks for the help all!
charlieLatchford
hi iam trying to do the same thing.. ive got a text field that contains an address each seperated with a "," i want to split into three new fields between the comers. for example
28, king road, new york
i want to be able to have the following field's
28
king road
new york
Does any one know any python script?
NiklasNorrthon
text = '28, king road, new york'
split_text = text.split(', ') # -> ['28', 'king road', 'new york']
A tip is to test the logic in the python interpreter before putting it together in a scirpt.
MarkVolz
I am trying to split a name field into lastname and firstname.  The name field may or may not contain a last name.
examples:
"Anderson, Bill"
"CHS Company"
I am able to pull out the last name from the field.  However I am having trouble getting the first name (if there is any) out.
I tried the code:
!TAX_NAME!.split(",", 1)[-1] if "," in !TAX_NAME! else ""   however ArcGIS reported a syntax error
BruceNielsen
I don't use the CalculateField command very often (IMO UpdateCursors are easier to understand), but I think the syntax you're looking for is:
if ',' in !TAX_NAME! then !TAX_NAME!.split(',',1)[-1] else ""
MarkVolz
Bruce,
Thank you for your reply.
I am still getting an error:
ERROR 000539: Error running expression: if ',' in "PETERSEN,ERIC J & GAIL" then "PETERSEN,ERIC J & GAIL".split(',',1)[-1] else "" <type 'exceptions.SyntaxError'>: invalid syntax (<string>, line 1)
Failed to execute (Calculate Field (2)).
BruceNielsen
Like I said, I don't use this syntax very often. Here's the amended code:
if ',' in !TAX_NAME! then !NEW_FIELD!=!TAX_NAME!.split(',',1)[-1] else "".
