Split text field into two new fields?
33998
17
11-24-2010 08:51 AM
DavidMedeiros
I'm a GIS MA student looking for some help on creating a Python script in ArcGIS for a class project. I have a text table with several fields (Tenant Name; Address; Sq Ft; Destination). The destination column contains information that I want to separate into two new fields - one for the first word in the original column and one for the second word in the original column. I then need to write this new info back into the original table.
What ArcPy commands should I be looking at to accomplish this? Can anyone point me to a similar finished script?
David
JasonScheirer
Esri Alum
You'll want to use AddField to add the new field for splitting, then use two CalculateValue calls -- one to populate the new field and another to truncate down the old field into the first word.
ChrisSnyder
Honored Contributor
If you want:
ORIG_FIELD = "My House"
SPLIT1 = "My"
SPLIT2 = "House"
The Python syntax for the Calculate Field tool would be:
SPLIT1 = !ORIG_FIELD!.split(" ")[0] #0 being the 1st word
SPLIT1 = !ORIG_FIELD!.split(" ")[-1] #-1 being the last word
JasonScheirer
Esri Alum
If you have records with multiple spaces this will fall down. There's an optional second argument to string.split to limit the number of splits performed:
SPLIT1 = !ORIG_FIELD!.split(" ", 1)[0] #0 being the 1st word
SPLIT2 = !ORIG_FIELD!.split(" ", 1)[-1] #-1 being the last word
And then you may only have one token, in which case you can use a conditional variable to rightly leave the second field as blank (otherwise, [0] and [-1] will be pointing to the same index in the list, meaning both fields are populated with the same value). So a more refined version would be:
SPLIT2 = !ORIG_FIELD!.split(" ", 1)[1] if " " in !ORIG_FIELD! else ""
DavidMedeiros
I should probably have waited to post this question until after the holiday so I could be trying this out in the lab, but this looks like it will be a great help, thank you!
All records in that field have single space, but some do only have one entry instead of two.
DavidMedeiros
Alright here's where I've gotten to on this:
[INDENT]# split table script
#add field step (keep)
import arcpy
from arcpy import env
inputTable = arcpy.GetParameterAsText(0)
inputField = arcpy.GetParameterAsText(1)  #"Dest" column, set in toolbox properties
#list fields (stops duplicate add fields)
theFieldList = arcpy.ListFields (inputTable, "Type")
arcpy.AddMessage ("the count" + str(len(theFieldList)))
#following exectues the add field (keep)
if len(theFieldList) == 0:
    arcpy.AddField_management(inputTable, "Type", "TEXT")
else:
    arcpy.AddMessage ("Field Exists")
#split field loop
theItemList = arcpy.SearchCursor (inputTable)  #gets all vlaues for table
for thisItem in theItemList:  #loops through vlaues
thisValue = thisItem.getValue (inputField)
split = !thisValue!.split(" ",1)[-1] if " " in !thisValue! else ""
setValue...[/INDENT]
The add field portion works, I'm not sure if I'm going in the right direction with the loop above and I don't know what the syntax is to set the value back into my new field. Does this look correct (aside from being incomplete)?
ChrisSnyder
Honored Contributor
If you want to write new data to the table you would need to use an update cursor (not a search cursor). Also, you have to use cursor syntax, not field calculator syntax.
DavidMedeiros
So I would drop the calculate field "split" command? Or use it together with the update cursor?
What I have so far is a new field, into which I want to place the second value from another filed (forget about truncating first field, not needed).
DavidMedeiros
Ok, I'm successfully updating the row - bigger achievement for me than you might think! 😉 But, I'm only getting the last character instead of the second word from the original row. Here's my script:
import arcpy
arcpy.AddMessage ("input " + inputTable)
else:
#split field loop
rows = arcpy.UpdateCursor (inputTable)  #gets all vlaues for table
for row in rows:  #loops through vlaues
    row.Type = row.Dest[-1]
    rows.updateRow(row)
del row
del rows
I know I need to change the modifier on the row.Dest[-1] syntax but I thought the [-1] gave me the second word?
ChrisSnyder
Honored Contributor
No, -1 gives you the last value (which may coincidentally be the 2nd item if there are only two items). For example:
list = ["a","b","c","d"]
list[0] = "a"
list[1] = "b"
list[2] = "c"
list[3] = "d"
list[4] = ERROR! Index out of range...
list[-1] = "d"
list[-2] = "c"
list[-3] = "b"
list[-4] = "a"
list[0:2] = ["a","b"]
