Split lines at point intersect - Split Lines at Points
1803
05-15-2013 06:34 PM
ErnestoCarreras3
Hi, any help is welcome??? I need to split some lines where it intersects with points. I used the Split Lines at Points but the output is not what I expected. Thanks in advanced!!
markdenil
It is a bit difficult to tell if the problem lies with the tool, with the data, with your use of the tool, or with your expectations.
Perhaps if you provided some more information about what you are putting in,
what you got out, what you expecetd to get out, and how it dissappointed you,
then someone might be able to help.
ErnestoCarreras3
Sorry for not been so clear. Basically I have two Feature Classes, one for points and one for liens. Some points intersect the lines. I want to run a script or tool that splits the line wherever the point intersects the lines (like valves on top of mains). I have tried the Split Lines at Points but it does not split the lines wherever the point intersect the lines.[ATTACH=CONFIG]24368[/ATTACH]
