Split a label over several lines, using commas, in python
5879
05-24-2016 11:32 PM
BenVan_Kesteren1
Hi All,
I am trying my hand at using python to modify my labeling to suit.
I have a column which contains peoples names, this column can contain between one and four names, all separated by a comma. See sample data here:
Currently when I label based on this column it looks pretty boring, what I would like is to split the names onto a new line, based on the comma. So essentially I want to find the comma, and insert a new line with the next name on it.
This is what it currently looks like, and the code:
def FindLabel ([BENVA.%Burial_Data.NAM], [SDE_SPATIAL.GISADMIN.waugh_road_graves.GIS_Authority_Link]   ):
  na = [BENVA.%Burial_Data.NAM]
  if na is None:
    na = [SDE_SPATIAL.GISADMIN.waugh_road_graves.GIS_Authority_Link]
  return na
Does anyone have any sample code they could provide that would achieve this? Alternatively give me some guidance as to how one would go about this???
Thanks very much everyone.
JoshuaBixby
MVP Esteemed Contributor
Since users have a bad habit of adding extra whitespace either before or after commas, I typically use a strategy of splitting, stripping, and rejoining the string so the stacked labels line up nicely.  Borrowing from Neil Ayres​'s example:
>>> na = "Fred ,Charlie, Neil"
>>> na
'Fred ,Charlie, Neil'
>>> print na.replace(",", "\n")
Fred
Charlie
 Neil
>>> print "\n".join(s.strip() for s in na.split(","))
Fred
Charlie
Neil
NeilAyres
You could try something like this
>>> na = "Fred, Charlie, Neil"
Fred
 Charlie
 Neil
FC_Basson
Just use the replace function to replace the commas with line breaks
  if na is None
  return na.replace (",", "\n")
JoshuaBixby
>>> na
Fred
Charlie
 Neil
Fred
Charlie
Neil
NeilAyres
Joshua,
much better.
BenVan_Kesteren1
Works beautifully, thanks for your assistance everyone
