Hi Everyone,I am working with a large dataset that I need to cursor through and retain the results of some spatial selects to generate another dataset for use outside of the GIS. The input are the junctions and edges of a road network. The process flow, idea anyway, is to grab an edge, perform a spatial select, figure out what junctions are connected, store this information and move on.This works very well, but is VERY slow. I have a spatial overlay approach to generate the same data but this is not satisfactory when the data are connected based on vertical elevation values. The code looks something like this:
arcpy.MakeFeatureLayer_management(edgeSource, 'edge_lyr')
arcpy.MakeFeatureLayer_management(junctionSource, 'junc_lyr')
ff = T.time()
edgeList = {}
nodePos = {}
goNogo = {}
edges = arcpy.SearchCursor(edgeSource, "", "")
for edge in edges:
newID = edge.getValue(edgeIDItem)
cost = edge.getValue(edgeCostItem)
expr = edgeIDItem + " = %s " % newID
arcpy.SelectLayerByAttribute_management ("edge_lyr", "NEW_SELECTION", expr)
arcpy.SelectLayerByLocation_management('junc_lyr', 'intersect', 'edge_lyr')
newEdge = []
juncs = arcpy.SearchCursor('junc_lyr')
for junc in juncs:
jid = junc.getValue(juncIDItem)
geom = junc.Shape.getPart()
newEdge.append(jid)
nodePos[jid] = (geom.X, geom.Y)
goNogo[jid] = [junc.getValue(nogoIDItem), junc.getValue(nogoDistItem)]
newEdge.append(cost)
if len(newEdge) == 3:
edgeList[newID] = newEdge
Does anyone have any ideas how a process like this might be sped up?Thanks!Steve
