Spatial Reference
1554
08-03-2011 09:03 AM
TedCronin
Has spatial ref changed for 10.1?
Where is the doc for prj files, since there is no node in catalog?
found it,  projected_coordinate_systems.pdf ArcGIS\doc
TedCronin
Yes, it has, and prj files are not included as a node, or installed, as I understand it.
DavidWynne
Yes, 'prj' files are gone at 10.1.  From the Python perspective it shouldn't matter much, we will still 'recognize' the files even though they don't technically exist.  So if you used a direct path to one of the installed prj files at 10.0 as input to the SpatialReference class--it will still work at 10.1 as it did at 10.0.
A few better options at 10.1 though, the sr name or factory code will work as well.
-Dave
ThomMackey
This is pretty interesting; is there documentation about the differences?
DavidWynne
Have a look at the SpatialReference page here: http://resourcesbeta.arcgis.com/en/help/main/10.1/index.html#/SpatialReference/018z0000000v000000/ and also here: http://resourcesbeta.arcgis.com/en/help/main/10.1/index.html#//002z0000001m000000.htm
Does that provide what you're looking for?
-Dave
