... but fine (Available) when I debug the script in a python IDE.
In this doc on page 116, I read that the setting of product and extensions is necessary only within stand alone scripts.
So in my py script, I first do the full check for the spatial analyst license, but it fails when I call this script from a command window.
If I open administrator, and see what I have installed, Spatial Analyst is there: Installed, Authorized and Permanent (non expiring). Single Use, so no license server to point at.
Does anyone have any hints about how I can solve this?
Yeah there are no desktop references. You will need to add these to your system paths, and possibly remove the server library references. Modifying depending on what drive/folder you have desktop installed. You will need the 64 bit desktop geoprocessing patch if you don't already.
So, the solution I linked to above describes what to do if desktop level of licensing is interfering with a server level of licensing.
What's the solution for the problem where I have a server level of licensing blocking me from running python scripts that rely on a desktop level of licensing?
From what I've read, one cannot revert or degrade their level of licensing, and I would not want to do this and run the risk of ArcGIS server then not functioning properly.
What I don't get is "why are desktop and server part of the same spectrum of licensing??!!"
Maybe I can register spatial analyst extension with my server license? has anyone done this ever?
