spatial license "NotLicensed" in stand alone script...
6560
16
04-09-2014 05:45 AM
MichaelBlom
... but fine (Available) when I debug the script in a python IDE.
In this doc on page 116, I read that the setting of product and extensions is necessary only within stand alone scripts.
So in my py script, I first do the full check for the spatial analyst license, but it fails when I call this script from a command window.
If I open administrator, and see what I have installed, Spatial Analyst is there: Installed, Authorized and Permanent (non expiring). Single Use, so no license server to point at.
Does anyone have any hints about how I can solve this?
Mike
JamesCrandall
Not exactly sure what your specific problem is that you are experiencing, but here is how you would check out a license, perform the analysis and then check the license back in.
      ### see if spatial analyst extension is available for use
      availability = arcpy.CheckExtension("Spatial")
      if availability == "Available":
         arcpy.CheckOutExtension("Spatial")
         print "SA Ext has been checked out"
      else:
         print "%s extension is not available (%s)"%("Spatial Analyst Extension",availability)
         print "Please ask someone who has it checked out but not using to turn off the extension"
         return
      #run the analysis
      arcpy.sa.Sample(rasters2, transect_in, outtab)
      #return the extension
      arcpy.CheckInExtension("Spatial")
MichaelBlom
thanks for replying James:
I have these lines:
if arcpy.CheckExtension("Spatial")=="Available":
    do something
else:
    arcpy.AddMessage("Spatial Analyst Licenses status: "+ arcpy.CheckExtension("Spatial"))
    arcpy.AddMessage(arcpy.ProductInfo())
I log the messages out:
Spatial Analyst Licenses status: NotLicensed
ArcServer
When I open ArcMap, it tells me I have spatial analyst.
MichaelBlom
Screen shot of what my administrator looks like:
MichaelBlom
screen shot of what my administrator looks like
MathewCoyle
Honored Contributor
As James said earlier you have to actually check out the license with this line.
MichaelBlom
Hi Matthew,
A "check-out" would occur after checking and seeing that the license is available - I am being told that no license is available, so I cannot proceed to check it out.
Besides, a check out would not apply for a stand-alone license, would it? only if there's a license server (which i don't have)
I think the real clue is when I print out this statment: arcpy.AddMessage(arcpy.ProductInfo())
and I get as a result:
ArcServer
This box has arcgis server and arcmap installed.  Perhaps there is a conflict with the "License Levels". Perhaps at the arcserver license level there is no access to desktop extensions via scripting?
Someone from ESRI?
MathewCoyle
Honored Contributor
Ahh yes. An ArcServer install cannot use desktop licenses.
Are you using 64 bit Python for desktop?
What is your output from sys.path?
MichaelBlom
sys.path[0] is just the path that the script is running from
I didn't print out other sys.path values, is there a specific value in the list?
the only version of python i have is here: D:\Python27\ArcGISx6410.2\python.exe
MathewCoyle
Honored Contributor
The entire sys.path output will tell you if you are reading from the desktop or server libraries or both.
