Spacially Referencing a series of polygons
5103
03-06-2015 08:45 AM
SheenaBerry
Hello, I am working on a script that produces a polygon grid from a series of irregularly spaced points (hence why I can't use fishnet).
I have managed to produce the desired grid but am unable to assign a spactial reference to the grid.
I have tried a number of ways such as assigning a Spactial Reference. I've tried to assign it to the individual points using a for loop:
PointsList=[]
for n in coordList:
    array=[]
    for coords in n:
        point=arcpy.Point(coords[0],coords[1])
        ptGeometry=arcpy.PointGeometry(point,arcpy.SpatialReference(factoryCode))
        array.append(ptGeometry)
    PointsList.append(array)
features = []
for feature in PointsList:
    #Create a Polygon object based on the array of points
    #Append to the list of Polygon objects
    features.append(
        arcpy.Polygon(
            arcpy.Array(*corner)) for corner in feature)
arcpy.CopyFeatures_management(features, outputName)
Or to the polygon durring its construction:
features = []
for feature in coordList:
    # Create a Polygon object based on the array of points
    # Append to the list of Polygon objects
    features.append(
        arcpy.Polygon(
            arcpy.Array([arcpy.Point(*coords) for coords in feature]), arcpy.SpatialReference(factoryCode)))
But both ways are giving me a runtime error.
I was wondering if it would be best to first create a feature class and then creat my polygons but I don't know how to write polygons to feature classes in python.
If someone could provide guidance it would be much apprechiated.
XanderBakker
Esri Esteemed Contributor
Below an extract from another post:
import arcpy
arcpy.env.overwriteOutput = True
sr = arcpy.SpatialReference(4326) # WGS 1984
# coords
lon_min = 175
lon_max = 185
lat_min = 0
lat_max = 10
polygon = arcpy.Polygon(arcpy.Array([arcpy.Point(lon_min, lat_min),
                                    arcpy.Point(lon_min, lat_max),
                                    arcpy.Point(lon_max, lat_max),
                                    arcpy.Point(lon_max, lat_min),
                                    arcpy.Point(lon_min, lat_min)]),sr)
fc_out = r"D:\Xander\GeoNet\AroundTheWorld\polygon01.shp"
arcpy.CopyFeatures_management([polygon], fc_out)
Notice that the Polygon is created from an Array of a list of Point objects.
In your post I see you are using an "array"  which is in your case a list and you use PointGeometry objects.
XanderBakker
import arcpy
# coords
lon_min = 175
lon_max = 185
lat_min = 0
lat_max = 10
SheenaBerry
Thanks Xander Bakker,
I guess my main issue was in the line:
arcpy.Array([arcpy.Point(*coords) for coords in feature]),arcpy.SpatialReference(factoryCode)))
where factoryCode was an input Coordinate system from the user of this script. I was hoping to have the code so I can create the polygons with a different spatial without having to open the scrip everytime. Here is a better example of what I am triing to do.
import arcpy
inputWorkspace = arcpy.GetParameterAsText(0)
outputName     = arcpy.GetParameterAsText(1)
factoryCode    = arcpy.GetParameterAsText(2) #input Coordinate System
coordList = [[[1, 2], [2, 4], [3, 7]],
                [[6, 8], [5, 7], [7, 2], [9, 5]]]
features = []
sr = arcpy.SpatialReference(factoryCode)
features.append(
     arcpy.Polygon(
          arcpy.Array([arcpy.Point(*coords) for coords in feature]), sr))
