Something simple that I can't seem to troubleshoot?
6374
9
09-09-2021 07:02 AM
RPGIS
by MVP Regular Contributor
I am currently working on a custom python tool that works until a certain point. The issue that I am having, and it is probably really simple but I can't seem to trouble shoot, is specifying the feature class using os.path.join method (unless I configured this wrong but running a random test proves otherwise).
The input workspace is set by a created gdb derived from one of the user inputs. Everything works until this point and I am now at a standstill. Any help on this would be greatly appreciated.
import arcpy
Project_GDB = 'input random gdb'
SubBoundaryFC_Name = 'SubdivisionBoundary'
SubdivisionFC = os.path.join(Project_GDB, SubBoundaryFC_Name)
SubBoundary = arcpy.management.FeatureToPolygon(FCs_forSubdivisionBoundary, SubBoundaryFC_Name)
arcpy.AddMessage('{} has been created.'.format(SubBoundary))
RPGIS
Hi @BlakeTerhune,
So I figured out the issue with part of the script that was giving me issues.
#Check to see if the following project already exists. If project exists, overwrite the existing project.
        Project_GDB = ''
        for root, directory, files in os.walk(folder_location):
                GDB = os.path.split(root)[-1]
                if GDB == ProjectGDB:
                        Project_GDB  = root
                else:
                        Project_GDB = arcpy.management.CreateFileGDB(folder_location, Project)
Further in the script I converted the output to a string and then utilized the os.path.join which worked as intended.
SubdivisionFC = os.path.join(str(Project_GDB), SubBoundaryFC_Name)
SubBoundary = arcpy.management.FeatureToPolygon(FCs_forSubdivisionBoundary, SubdivisionFC)
arcpy.AddMessage('{} has been created.'.format(SubBoundaryFC_Name))
So this simple solution was really all I needed. Here is the message result that it generated.
SubdivisionBoundary has been created.
David_Brooks
@RPGIS you haven't declared this variable:
David
..Maps with no limits..
RPGIS
I accidently left out of the snippet for this little piece here by mistake.
FCs_forSubdivisionBoundary = []
It is derived from using walk to append each feature class in the database based on matching names.
BlakeTerhune
Are you getting a particular error message? If so, please paste the entire traceback if you can. Is everything in FCs_forSubdivisionBoundary a line or polygon feature class? Also, try using SubdivisionFC as the out_feature_class for FeatureToPolygon() instead of SubBoundaryFC_Name (because no workspace is specified).
RPGIS
Hi @BlakeTerhune,
Here is the error message that I keep getting when it runs.
Failed script Import Test...
  File "*:\CAD Exporting Test\Default.tbx#ImportTest_Default.py", line 207, in <module>
  File "*:\CAD Exporting Test\Default.tbx#ImportTest_Default.py", line 183, in ScriptTool
  File "*:\''\''\AppData\Local\Programs\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\ntpath.py", line 76, in join
    path = os.fspath(path)
TypeError: expected str, bytes or os.PathLike object, not Result
Failed to execute (ImportTest).
Not sure what this error refers to but I can't seem to bypass it for some reason. I am thinking that the issue is either a syntax issue or an output error.
BlakeTerhune
That error means you're taking a Result object (output from a geoprocessing tool) and inputting it directly into something else without unpacking it.
I can't say exactly where it's happening since we don't have the whole script but look on line 183. Something there is getting a result object when it should be getting something more specific (like a string path to a feature class).
RPGIS
Hi @BlakeTerhune,
        Project_GDB = ''
                        Project_GDB  = root
                else:
by Anonymous User
Not applicable
It can be tricky trying to troubleshoot script tools but there are some ways you can get error messages.
import arcpy
try:
    # As Brooks mentioned, should SubdivisionFC be FCs_forSubdivisionBoundary below?
except:
    arcpy.AddError(arcpy.GetMessages(2))
or if you want to test the script in an IDE as a standalone/script tool script and use env.workspace:
import arcpy
Project_GDB = arcpy.GetParametersAsText(0) # value assigned when ran as script tool
if Project_GDB == '' or not Project_GDB:
    Project_GDB = 'input random gdb' # default value for standalone
SubBoundaryFC_Name = arcpy.GetParametersAsText(1)
if SubBoundaryFC_Name == '' or not SubBoundaryFC_Name:
try:
    arcpy.env.workspace = Project_GDB
    # if the target fc's are in the project_gdb, you should be able to reference them by name and not have to use os.path.join if you set your env.workspace
    SubBoundary = arcpy.management.FeatureToPolygon("FCs_forSubdivisionBoundary", SubBoundaryFC_Name)
except:
BlakeTerhune
@Anonymous User has some good suggestions for error handling. I want to point out that the except like that will catch all exceptions but will only attempt to output specifically arcpy geoprocessing errors. A more well rounded solution would be a specific except and a general except for everything else.
import arcpy
try:
except arcpy.ExecuteError:
except Exception as e:
    arcpy.AddError(e)
Error handling with Python—ArcGIS Pro | Documentation
MichaelVolz
Esteemed Contributor
I would suggest adding print statements for variables to ensure that they are being populated as expected.
