Snap Error Using Arcpy
2243
08-30-2023 12:04 PM
tzz_12
Hi Everyone,
I am not sure why I am getting this error message," ERROR 000800: The value is not a member of End | Vertex | Edge" when I try to use the snap tool using arcpy. Here is my simplified script below that I tested in python command window, which gave me the same error as my script:
snapEnv = ['WBDHU12',"EDGE",'5 Meters']
arcpy.edit.Snap('FeatureClassName',snapEnv)
Thanks for your help!
DavidPike
MVP Notable Contributor
Hmmm I found the help a bit confusing, but perhaps it just needs to be wrapped in another set of brackets.
snapEnv = [['WBDHU12',"EDGE",'5 Meters']]
DavidPike
tzz_12
Thanks David! It works now.
RhettZufelt
If you use the GP tool and copy the python snippet, this is what you get, and is working for me.
Though, not really what the documentation says.
snapEnv = "WBDHU12 EDGE '5 Meters'"
R_
Also, code formatting.
