slicing error in python in ArgGIS 10.4.1 for desktop
2055
01-01-2019 02:18 PM
EvanD
I am attempting to run a script that throws an error in a seemingly simple statement in bold below:
for i in range(1,len(part)):
cut=part[i-1:i+1]
sides.append(arcpy.Polyline(cut,SR))
I ran the script up to where part is defined then entered:
>>> part
<Array [<Point (2524240.5113, 2562562.7555, #, #)>, <Point (2524240.8774, 2562712.7555, #, #)>, <Point (2524290.3774, 2562712.6347, #, #)>, <Point (2524290.0113, 2562562.6347, #, #)>, <Point (2524240.5113, 2562562.7555, #, #)>]>
>>> c = part[0:2]
Runtime error
File "<string>", line 1, in <module>
File "c:\program files (x86)\arcgis\desktop10.4\arcpy\arcpy\arcobjects\mixins.py", line 161, in __getitem__
return convertArcObjectToPythonObject(self._arc_object.GetObject(index))
AttributeError: Array: Error in parsing arguments for GetObject
I have tried on two computers, one with python 3 also installed and one without. The python directories returned by sys.path are all there (although the path also includes the non-existent 'C:\\WINDOWS\\SYSTEM32\\python27.zip').
Any ideas on how to troubleshoot this? Thanks.
DanPatterson_Retired
The array needs getObject to access the individual points. The supported properties and methods are listed in the help
Array—ArcPy classes | ArcGIS Desktop
JoshuaBixby
MVP Esteemed Contributor
Are you running 10.4.1 or 10.4?  Prior to 10.4.1, ArcPy geometry objects did not support indexing and slicing.  I believe that included ArcPy array objects as well, but I don't have access to a 10.4 machine to test.
Your code works fine in 10.6.x, and I believe it will also work fine in 10.5.x:
>>> import arcpy
>>> coords = [
...   (2524240.5113, 2562562.7555),
...   (2524240.8774, 2562712.7555),
...   (2524290.3774, 2562712.6347),
...   (2524290.0113, 2562562.6347),
>>> part = arcpy.Array(arcpy.Point(*coord) for coord in coords)
>>> part
>>> part[0:2]
<Array [<Point (2524240.5113, 2562562.7555, #, #)>, <Point (2524240.8774, 2562712.7555, #, #)>]>
>>> c = part[0:2]
EvanD
It says 10.4.2.5686.
JoshuaBixby
Build 5686 is 10.4.1 final.  Although My Esri states my enhancement requests for geometry slicing was implemented in 10.4.1, it could be wrong and 10.5 instead. I know it works in 10.6.1, so the question remains what version exactly does it start working.
It has worked in Pro since I can remember... the arcpy's differ though
import arcpy
coords = [(2524240.5113, 2562562.7555), (2524240.8774, 2562712.7555), (2524290.3774, 2562712.6347), (2524290.0113, 2562562.6347), (2524240.5113, 2562562.7555) ]
part
part[:2]
pnts = [p for p in part]
pnts
arr = np.asarray([(p.X, p.Y) for p in part])
arr
array([[2524240.5113, 2562562.7555],
       [2524240.8774, 2562712.7555],
       [2524290.3774, 2562712.6347],
       [2524290.0113, 2562562.6347],
       [2524240.5113, 2562562.7555]])
np.mean(arr, axis=0)
array([2524260.45774, 2562622.70718])
