Sharing Options for Python Map Image Layer Automation
2564
03-22-2020 03:54 PM
ClintonCooper2
Having been referred to the overwrite option for sharing a map image layer in python, I am wondering if there is an option to allow for sharing with a group or, within the organization or, with everyone.  In the documentation for the method, there does not seem to be a sharing parameter option.  I was thinking about a solution like where I search for the layer and then update the parameter was  available option if there is no method in the other sharing option.  However i cannot get this code to actually update that parameter.   Here is the code I am trying:
from arcgis.gis import GIS
portal = "https://sdc01acgicpw01s.corp.company.com/portal/home/content.html"
user = "      "
password = "     "
service = "WebUpdate"
gis = GIS(portal, user, password)
print("Search for original SD on portal…")
search_results = gis.content.search("{} AND owner:{}".format(service, user), item_type="Map Image Layer")[0]
print("Found SD: {}, ID: {} ".format(search_results.title, search_results.id))
feature_layer_item = search_results[0]
print("Setting sharing options…")
feature_layer_item.share(everyone=True)
print("Finished updating: {} – ID: {}".format(feature_layer_item.title, feature_layer_item.id))
Anything I can do to through code to change the sharing for a map image layer?
ClintonCooper2
This worked, thank you!
JakeSkinner
Esri Esteemed Contributor
Hey Clinton,
Try the below:
# Varibales
portal = 'https://sdc01acgicpw01s.corp.company.com/portal'
username = 'gisuser'
password = '******'
mapImageLayer = 'WebUpdate'  # Service Name
# Connect to Portal
gis = GIS(portal, username, password)
# Search and share map service
search_results = gis.content.search('title: {0} AND owner: {1}'.format(mapImageLayer, username), item_type = 'Map Image Layer')
map_image_item = search_results[0]
map_image_item.share(everyone=True)
print("Finished")‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
ClintonCooper2
