Share as Route Layer ignoring my output folder
819
03-13-2025 08:02 AM
AndreaStaten
I am scripting the process of creating routes for some of our crew members. I have come across a problem where I assign a value for the output_folder and it is essentially ignored and just shares it directly to my content.
Here is my code, some of it has been edited to remove sensitive information:
# This renames the name field in the Route Layer and shares it online. It is supposed to share it to the Meter folder but this part is not working right now.
Date3 = time.strftime("%m%d")
try:
# Set the active portal
arcpy.SignInToPortal("https://gis.issue.com/issuegisportal", "admin", "Password123")
# Reference the current project and map
project = arcpy.mp.ArcGISProject("CURRENT")
map = project.listMaps("Map")[0] # Adjust "Map" to the name of your map if different
# Find the route layer in the Contents pane
route_layer = None
for layer in map.listLayers():
if layer.name == "Route_MetersToRead": # Replace with the name of your route layer
route_layer = layer
break
if route_layer is None:
raise Exception("Route layer not found in the Contents pane")
route_layer_path = f"S:\Meter Route\MeterRoute\MeterRoute.gdb\Routes1m31w84"
# Update the 'Name' field values
with arcpy.da.UpdateCursor(route_layer_path, ["Name"]) as cursor:
for row in cursor:
row[0] = f"Route_MetersToRead_{Date3}" # Replace with the new name you want
cursor.updateRow(row)
print("Field 'Name' updated successfully.")
# Define the output route layer name and folder
route_layer_name = f"Route_MetersToRead_{Date3}"
output_folder = 'Meter'
# Share the route as a route layer
arcpy.na.ShareAsRouteLayers(route_layer, route_layer_name, output_folder)
# Check if the route layer was shared successfully
print("Route layer shared successfully.")
except Exception as e:
print(f"An error occurred: {e}")
arcpy.AddError(str(e))
Also worth noting, I 100% have access and privileges to share to this folder, as I can manually do it. I also have tried scripting it to export to other folders and it is still ignored, so it is not a specific issue with this folder.
Any ideas what could be causing this?
JakeSkinner
Esri Esteemed Contributor
Hi @AndreaStaten,
This could be a possible bug.  You could try adding additional code to move the layer after it's created.  For example, add a variable and print statement after the following line to see what's returned in the string:
result = arcpy.na.ShareAsRouteLayers(route_layer, route_layer_name, output_folder)
print(result)
If the item ID is returned, you could move the layer with the following:
from arcgis.gis import GIS
# Connect to Portal
gis = GIS("https://gis.issue.com/issuegisportal", "admin", "Password123")
# Move item
item = gis.content.get(item_id)
item.move('Meter')
