Setup VSCode with ArcGIS Pro 2.8.7 for Python Development
1597
03-12-2023 01:29 PM
Sunnywaygis
Hi There, I am trying to configure ArcGIS Pro 2.8.7/VSCode for Python scripting using cloned environment. I wanted to check with community members to see if there are any recommended steps for setting this development environment correctly.
Appreciate your feedback.
Thanks
by Anonymous User
Not applicable
Nothing special, just point to the python environment that you want to use.
C:\Users\you\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\python.exe  (or where ever your cloned env is)
Sunnywaygis
Thanks JeffK, I did point to the cloned path and it works.
While debugging I get this error, not sure what is causing this..
by Anonymous User
Not applicable
Nice, and you'll have to create a debugging file for debugging.  This article has a good step by step that you can follow to create one: debug-python-in-vscode   Just the part for creating the launch.json file.
