SetParameterAsText To View Python Tool Results
11905
32
06-08-2016 02:47 PM
DevinUnderwood2
I have the following which I can successfully get my desired results with the input prompt standalone script.  Yet, I prefer that a tool I created to be used and display the results. What am I missing in order to view the results?
#Import Modules
import csv,os,arcpy
#Set variables
ifile  = open('PythonShellSave.csv','r')
reader = csv.reader(ifile)
featureclass = input("Name of the feature class ? ")
#featureclass = arcpy.GetParameterAsText(0)
#Set path location of Excel (CSV) file
path = 'C:\WriteMxdInfoToExcel'
os.chdir(path)
#CSV Module terminology row is horizontal & field is vertical;column is horizontal & row is vertical for excel.
for row in reader:
          for field in row:
              if field == featureclass:
                  print row [4] + " " + featureclass
arcpy.SetParameterAsText(1,row)
#Close Excel (CSV) file
ifile.close()
DanPatterson_Retired
when you run a script, you should have a window open up that shows the results of the processing... someone turned it off... turn it back on... can't help with that one but it is there.  The window should not close until you are ready to close it.  The Results window is backup but it doesn't show the progress of the script and other fluff as it goes.  Rebecca, check it, I am on iThingy so can't help
GOT IT
set to foreground processing... look at the figure here
Foreground and background processing—Help | ArcGIS for Desktop
DevinUnderwood2
Great advice, I just recently came across that article. I do see the results window, but it doesn't display the actual information I want.
I want to see the information that I can see when I run the script as a stand alone. The  python shell results is what I want to see in the above window for the tool.
Maybe the Add Message was never correctly displaying, does it differ from a print when viewing in the python shell ?
DevinUnderwood2
Apparently you can't see AddMessage in python shell.
I commented out the AddMessage function. I used just arcpy.AddMessage which does work when testing with featureclass. I need to get it to work with final which I think it is having trouble being a looped result.
The code below produced the following in below results window.
Import Modules
import csv,os,arcpy
#Set variables
#featureclass = input("Name of the feature class ? ")
path = r'C:\Users\dunderwood\Documents\My Python Scripts\WriteMxdInfoToExcel'
arcpy.env.workspace = path
#Create Function
#def myMsgs(message):
 #   arcpy.AddMessage(message)
  #  print(message)
for row in reader:
          for field in row:
                  final = row[4] + " " + featureclass
                  #print(final)
                  #myMsgs(message)
arcpy.AddMessage('All Mxds associated with fc = {}'.format(featureclass))
ifile.close()
DevinUnderwood2
I am getting a returned value of None with the following excerpt of my code.
print viewresults + str(arcpy.AddMessage('All Mxds associated with fc = {}'.format(viewresults)))
What does None refer to ?
you can't jumble them together
msg = "All Mxds associated with fc = {}".format(viewresults)
print(msg)
arcpy.AddMessage(msg)
extra lines don't hurt and print only is used when the script is being run outside of an arctoolbox tool
and AddMessage is used to report tools results .... ie it is the toolbox equivalent of print
DevinUnderwood2
I removed the print statement.  I receive an error as follows.
  File "...\ReadMxdFCCSV.py", line 34, in <module>
NameError: name 'viewresults' is not defined
Failed to execute (readmxdFC).
Despite previously setting viewresults as a variable
Any Idea why I am having this error ?
with respect to the addmessage line, where is viewresults defined? if viewresults is being defined within a loop for instance, it may never be seen.  So to track down the error, put
viewresults = "view results not defined"
way up at the top of the script so that it always has a value.  If that message is returned, it is not being derived or returned elsewhere
DevinUnderwood2
Yes it is on a loop.
for row in reader:
          for field in row:
                  viewresults = (row[4] + " " + featureclass)
then do what I said since
is never correct that is why it doesn't get a value. so put the line I suggeste before line 01 and run it again to see what I mean
print statements are cheap... throw them in even if you think something is going to work, it will save you hours of debugging
