Set Environment to Current Extent
1737
06-11-2012 10:49 PM
JulianInskip
I am trying to set the environment for my output files to my current map extent so that when I run a Select_analysis it only uses the features in the current extent.
I found the following code on a previous forum and thought I could use it to set my env.extent:
import arcpy
import arcpy.mapping
## Sets the MXD file
IMXD = arcpy.mapping.MapDocument("CURRENT")
## Sets the Dataframe
DF = arcpy.mapping.ListDataFrames(IMXD, "Layers")[0]
print DF.extent
This works well and shows me the extent of my current map extent.
I tried to modify it slightly to use the extent output to set the env.extent so that whenever I run the script it will only use the current extent (I know that this will limit me to only running it in ArcMap with a specific extent)
import arcpy
arcpy.env.extent = "DF"
This is incorrect and gives me an error (Runtime error <type 'exceptions.RuntimeError'>: UNKNOWN).
I have clearly done something wrong here. Am I on the right path or way off target here?
Thanks for any help.
Julian.
MarcinGasior
Try to pass the extent object from data frame to environment setting.
This code works for me:
arcpy.env.extent = DF.extent
NobbirAhmed
Esri Alum
Set extent as:
JulianInskip
WOW, that was an exceptionally fast reply.
Thanks Marcin and Nobbir, your replies worked and tool is working brilliantly now.
