server py api
4687
10
08-02-2011 11:19 AM
TedCronin
MVP Alum
WING on Win 7 Is beautiful...
So, how do I import _server_admin remotely, Esri python gods?  I want to rewrite all my AGSSOM subprocess code using the new server admin, but I want to write it locally and access the package.  Can I just add the server in my path using UNC to the server admin api?  Can this even be done, since I would be running 32 bit calling a module written in 64 bit?
eddiequinlan
fyi......
In regards to stopping the service to perform updates:  I was having the same issue, but when I changed the map service "parameters" setting "Lock Database schema" to unchecked I have had no issues with updates.  If I am overlooking something by doing this, anyone, please fill me in.
Eddie
