SelectLayerByLocation 'WITHIN_A_DISTANCE' from point vs 'INTERSECT' point buffer
2401
06-20-2013 01:25 PM
CharlesArnold
I'm having trouble understanding the 'WITHIN_A_DISTANCE' option for arcpy.SelectLayerByLocation_management.
When I use arcpy.SelectLayerByLocation_management(lbTaCentroidsLayerName, 'WITHIN_A_DISTANCE', sitePntGeom, '25 Miles'), I get 815 points selected, but when I do arcpy.SelectLayerByLocation_management(lbTaCentroidsLayerName, 'INTERSECT', siteBufferFc) with a 25 miles buffer of the sitePntGeom, I get 1182 points selected.
Am I missing something obvious?
In [1]: import arcpy
In [3]: siteLon, siteLat = -122.276518, 47.191838
In [4]: sitePoint = arcpy.Point(siteLon, siteLat)
In [7]: sitePntGeom = arcpy.PointGeometry(sitePoint, wgs1984SpatialRef)
In [13]: lbTaCentroidsLayerName = 'centroidsFeatureLayer'
In [14]: arcpy.MakeFeatureLayer_management(centroidsFeatureClassName, lbTaCentroidsLayerName)
Out[14]: <Result 'centroidsFeatureLayer'>
In [15]: arcpy.SelectLayerByLocation_management(lbTaCentroidsLayerName, 'WITHIN_A_DISTANCE', sitePntGeom, '25 Miles')
Out[15]: <Result 'centroidsFeatureLayer'>
In [16]: int(arcpy.GetCount_management(lbTaCentroidsLayerName).getOutput(0))
Out[16]: 815
In [17]: siteBufferFc = 'in_memory/siteBuffer'
In [18]: arcpy.Buffer_analysis(sitePntGeom, siteBufferFc, '25 Miles')
Out[18]: <Result 'in_memory\\siteBuffer'>
In [19]: arcpy.SelectLayerByLocation_management(lbTaCentroidsLayerName, 'INTERSECT', siteBufferFc)
Out[19]: <Result 'centroidsFeatureLayer'>
In [20]: int(arcpy.GetCount_management(lbTaCentroidsLayerName).getOutput(0))
Out[20]: 1182
In [21]:
DarrenWiens2
I assume it's because 'sitePntGeom' is assigned a geographic coordinate system (wgs1984SpatialRef), making oblong buffers, while SelectLayerByLocation may be using a projected coordinate system, making a circular search area. Is the feature class (centroidsFeatureClassName) projected? In any case, buffering unprojected data is not recommended.
edit: actually, buffering geographic data results in geodesic buffers, which are more accurate than Euclidean buffers made for projected data.
CharlesArnold
Why is buffering unprojected data not recommended?
DarrenWiens2
Oh, on further inspection apparently buffering geographic data is preferred (news to me) in order to avoid distortions introduced by the projection.
I still feel like this is the cause of the difference in selected points, although now I'm questioning everything.
