Selecting Features by Location
5017
13
06-11-2012 11:17 AM
LarissaPizzolato
Hello,
I am trying to select features by location from the "tableName_vctor" layer as defined (and highlighted in red), then export them to a new shapefile and am receiving the following errors (refer to the blue section):
ERROR 000622: Failed to execute (Select Layer By Location). Parameters are not valid.
ERROR 000628: Cannot set input into parameter search_distance.
any insight as to how to fix these errors is much appreciated
thank-you in advance!
try:
    # Iterates through each of the input text files
    for v in list(table):
        # Removes the file extension
        tableName = os.path.splitext(v)[0]
        # Variables
        tableName_line = tableName + str("_line.shp")
        tableName_vctor = tableName + str("_vctor.shp")
        tableName_e = tableName + str ("_e.shp")
        gate = r"C:\gis\gate.shp"
        tableName_sim = tableName + str("_sim.shp")
        # Creating vectors from xy coordinates
        gp.Toolbox = r"C:\Program Files\ArcGIS\ArcToolbox\Toolboxes\Military Analyst Tools.tbx"
        gp.TableToLine_ma(v, tableName_line, "Decimal Degrees", "sLat", "sLon", "eLat", "eLon", "False", "False")
        gp.Project_management(tableName_line, tableName_vctor, "PROJCS['LCC']")
        #Selecting vectors that intersect a line, then points that intersect the vector, then removing the initial selection
        gp.SelectLayerByLocation(tableName_vctor, "intersect", gate, "NEW_SELECTION")
        gp.SelectLayerByLocation(tableName_e, "intersect", tableName_vctor, "ADD_TO_SELECTION")
        gp.SelectLayerByLocation(tableName_vctor, "intersect", gate, "REMOVE_FROM_SELECTION")
        # Write the selected features to a new feature class in the folder
        gp.CopyFeatures(tableName_sim, r"C:\gis\temp")
except:
    #If an error occurred while running the script, then print the messages
    print gp.GetMessages()
MathewCoyle
Honored Contributor
You are referencing layer files that were never created it looks like. MakeFeatureLayer creates a temporary layer in memory, not a layer file.
MathewCoyle
Honored Contributor
You can only do selections on layers, not feature classes.
Also, this is the syntax.
SelectLayerByLocation_management (in_layer, {overlap_type}, {select_features}, {search_distance}, {selection_type})
LarissaPizzolato
When creating the feature layer using the following code,
# Make a layer from the shapefiles
gp.MakeFeatureLayer("tableName_e.shp", "tableName_e_lyr")
gp.MakeFeatureLayer("tableName_vctor.shp", "tableName_vctor_lyr")
I am trying to call on shapefiles that were made earlier in the code (the files in blue), yet I am getting this error:
Failed to execute. Parameters are not valid.
ERROR 000732: Input Features: Dataset tableName_e.shp does not exist or is not supported
Failed to execute (MakeFeatureLayer).
MarcinGasior
The shapefile you specified is not found in geoprocessing workspace or gp.workspace was not declared.
So you have to:
- declare gp.workspace which contains your shapefiles
or
- provide full path (or variable with path) in gp.MakeFeatureLayer_management() tool
LarissaPizzolato
# Make a layer from the feature class
        gp.MakeFeatureLayer_management(gate, "gate_lyr")
        gp.MakeFeatureLayer_management(tableName_e, "tableName_e_lyr")
        gp.MakeFeatureLayer_management(tableName_vec, "tableName_vec_lyr")
        print "Feature Layers created."
        #Selecting the vectors that intersect the gate
        gp.SelectLayerByLocation_management(tableName_vec_lyr, "intersect", gate_lyr)
        # Add to selection, points that intersect with the previously selected vectors
        gp.SelectLayerByLocation_management(tableName_e_lyr, "intersect", tableName_vec_lyr, "ADD_TO_SELECTION")
        # Remove initial vector selection
        gp.SelectLayerByLocation_management(tableName_vec_lyr, "intersect", gate_lyr, "REMOVE_FROM_SELECTION")
        gp.CopyFeatures(tableName_e_lyr, tableName_sim)
The feature layers are successfully created, and the first "select layer by location " works, but it doesn't seem to perform the 2 subsequent "select layer by location"'s.
MathewCoyle
Honored Contributor
You need to use the proper syntax.
SelectLayerByLocation_management (in_layer, overlap_type, select_features, search_distance, selection_type)
http://webhelp.esri.com/arcgisdesktop/9.3/body.cfm?id=1877&pid=1865&topicname=Select%20Layer%20By%20...
You are trying to insert "ADD_TO_SELECITON" in the search distance parameter.
LarissaPizzolato
It says that the search distance is optional so I have tried to set it as "None", "Null", "No_Value", "", " ", "0", as I do not want to create a buffer, but rather only select the points that intersect with the specified vector... I can't seem to find any other alternative placeholder to setting it as blank.
MathewCoyle
Honored Contributor
Either of these should work.
"" or "#"
gp.SelectLayerByLocation_management(tableName_e_lyr, "intersect", tableName_vec_lyr, "", "ADD_TO_SELECTION")
gp.SelectLayerByLocation_management(tableName_vec_lyr, "intersect", gate_lyr, "#","REMOVE_FROM_SELECTION")
Are you getting an error or anything when these execute? Or just unexpected behaviour?
NobbirAhmed
Esri Alum
After you set an empty string (red) for the search_distance parameter:
Please enclose the call with try-except block as follows:
try:
except:
    print gp.GetMessages(2)
What error message do you get now?
LarissaPizzolato
I added the try and except statement around the select layers by location by did not get any error messages generated.
This is what printed in the python shell:
Feature Layers created. (suggesting that the feature layers were created)
Selecting vectors that intersect the gate for:20041115011426_20041122011013 (this is the start of the select by location commands)
(i'm not sure why this is occuring after the feature layers should have aExecuting: MakeFeatureLayer E:\temp\5464648_vec.shp vec_lyr # # "CP CP VISIBLE NONE;startX startX VISIBLE NONE;startY startY VISIBLE NONE;dispX dispX VISIBLE NONE;dispY dispY VISIBLE NONE;sLat sLat VISIBLE NONE;sLon sLon VISIBLE NONE;theta theta VISIBLE NONE;pCorr pCorr VISIBLE NONE;pkStr pkStr VISIBLE NONE;cCorr cCorr VISIBLE NONE;conf conf VISIBLE NONE;velX velX VISIBLE NONE;velY velY VISIBLE NONE;endX endX VISIBLE NONE;endY endY VISIBLE NONE;eLat eLat VISIBLE NONE;eLon eLon VISIBLE NONE"
Start Time: Tue Jun 12 12:57:06 2012
Executed (MakeFeatureLayer) successfully.
End Time: Tue Jun 12 12:57:06 2012 (Elapsed Time: 0.00 seconds)
I know that the select by location should work because when I do it manually in ArcMap, i'm able to select several features through following the similar set of commands but the automation for this step doesn't seem to run.
        # Variables...
        tableName_e = tableName + str("_e.shp")
        tableName_vec = tableName + str("_vec.shp")
        gate = r"E:\test\gate.shp"
        end_lyr = tableName + str("_e.lyr")
        vec_lyr = tableName + str("_vec.lyr")
        gp.MakeFeatureLayer_management(tableName_e, "end_lyr")
        gp.MakeFeatureLayer_management(tableName_vec, "vec_lyr")
        print "Selecting vectors that intersect the gate for:" + str(tableName)
        # Process: Select Layer By Location...
        gp.SelectLayerByLocation_management(vec_lyr, "INTERSECT", gate_lyr, "", "NEW_SELECTION")
        # Process: Select Layer By Location (2)...
        gp.SelectLayerByLocation_management(end_lyr, "INTERSECT", vec_lyr, "", "ADD_TO_SELECTION")
        # Process: Select Layer By Location (3)...
        gp.SelectLayerByLocation_management(vec_lyr, "INTERSECT", gate_lyr, "", "REMOVE_FROM_SELECTION")
        gp.CopyFeatures_management(end_lyr, tableName_sim,  "", "0", "0", "0")
