Selecting Data Frames for Python Scripting
4678
7
08-29-2011 10:50 AM
ChadFoster
I have a .mxd that contains 5 data frames.  I am trying to write a script that will first select the appropriate data frame for the script to process.  Is this possible?
JakeSkinner
Esri Esteemed Contributor
You can do this by specifying an index value.  Say, for example, you want to select the data frame called 'Philadelphia', and it's the 3rd data frame in your MXD.  You would use the following:
df = arcpy.mapping.ListDataFrames(mxd)[2]
The first data frame in your MXD starts with index 0.  Here is some further information:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00s30000001p000000.htm
ChadFoster
ok, i get that syntax and it appears like it is working but I would like to select and activate that data frame.  Maybe my question should have been, can I activate a data frame for my script to work?
deleted-user-1T_bOHag6M8d
What are you trying to accomplish in the selected dataframe?
ChadFoster
I have a MXD with 5 data frames, the main data frame is running the Data Driven Pages for my Assessor Parcel Maps.  The second data frame shows the Township and Range of the page, third data frame shows the section within the township and range, and the fourth data frame shows the different divisions within the section.  I want to write a script that will prompt the user for those three pieces of information - TR, SECTION, and DIVISION - and have the page update automatically.
In my limited Python Scripting I am having trouble selecting layers in non active data frames.
The next step will be to map the selections according to users input......
import arcpy
mxd = arcpy.mapping.MapDocument ('CURRENT')
df = arcpy.mapping.ListDataFrames(mxd) [1]
mxd.activeView = df
layer = arcpy.GetParameterAsText (0)
grid = arcpy.GetParameterAsText (1)
arcpy.AddMessage (grid)
selstring = "TAG LIKE " + "'" + grid + "'"
arcpy.AddMessage("Selection string = " + selstring)
arcpy.SelectLayerByAttribute_management (layer, "NEW_SELECTION", selstring)
import arcpy
mxd.activeView = df
Sounds to me like you need to run the SelectLayerByAttribute on each dataframe by constructing a for loop for ListDataFrames.
For example:
import arcpy
dfs = arcpy.mapping.ListDataFrames(mxd)
for df in dfs:
    mxd.activeView = df
ChadFoster
When I try that code for selecting a different data frame it disappears from my table of contents.
I'm not sure I understand. The data frame disappears? As in, it gets deleted from the mxd?
