Select Input Parameters from Dropdown List Showing Current Map Layers
3373
05-10-2011 10:04 AM
AmySmith1
Hello!
I'm very new to creating script tools, and I recently started working with the Tool Validator. I'd like the users of my script tool to be able to select their input parameters from a dropdown list showing current map layers that match the input type (for example, if the input is specified as the type "Feature Class", a list of feature classes in the current map document would appear as options in a dropdown list). Most of the ArcGIS tools automatically do this.
Although it doesn't work, this is what I have come up with so far (input 1 is a Feature Class, and input 2 is a Raster):
def initializeParameters(self):
    mxd = arcpy.mapping.MapDocument("CURRENT")
    featureLayerList = []
    rasterLayerList = []
    for lyr in arcpy.mapping.ListLayers(mxd):
      if lyr.isFeatureLayer == True:
        featureLayerList.append(lyr.name)
      elif lyr.isRasterLayer == True:
        rasterLayerList.append(lyr.name)
    self.params[1].filter.list = featureLayerList
    self.params[2].filter.list = rasterLayerList
    return
I would greatly appreciate any advice!
Ride the lightning,
Amy
www.wolfmapper.com
LoganPugh
It should work like this by default (no ToolValidator modifications needed) as long as your input parameter is of type Feature Layer.
AmySmith1
Thanks, lpugh01. I don't know why, but it is not working this way by default. Does anyone have any idea why this might be happening?
Amy
www.wolfmapper.com
AmySmith1
Ah, I see, there's a difference between a Feature Class and a Feature Layer. Like I said, I'm new at this! Thanks again for your help. 😮
Amy
www.wolfmapper.com
