Select features by subtype
1456
5
11-29-2010 02:15 AM
LeeMusto
I have numerous geodatabase feature classes, each of which contains several subtypes, so in total there are approx 150 different subtypes. I need to create new separate feature classes for each of those subtypes, containing all of the features of that particular subtype (so that I can output them to a text file). I am quite new to scripting, but believe I could achieve this if I created a list of all those subtypes. However, I assume I should be able to do this without the need to create the list. I understand loops, but it's how to group the features according to subtype that I am struggling with - any tips would be much appreciated.
ChrisMathers
Well you can
iterate over the feature classes,
  use a cursor to get a set of the values in the subtype field
  iterate over the values in the set
    select by the value
    featureclasstofeatureclass the selection.
LeeMusto
Chris,
Thanks for your reply. I understand how to do it for one subtype using the method you describe, but it's how to iterate over each subtype, without knowing what those subtypes are e.g  if I have 10 feature classes, each with 10 subtypes, I want to automatically create 100 new feature classes - some subtypes may have features in them, some may be empty, but I still need it to produce the feature classes. In the meantime, I have created simple tables which contain the subtypes and written a script which iterates through each subtype - which works fine for this set of data, but it would be useful to know so that if I have a new set of data in the future I did not have to manually create the tables.
ChrisMathers
Ah ok. Well you need only to know which field holds the subtype values.
for FC in listofFC:
    s_cursor=arcpy.SearchCursor(FC)
    subtypes=[]
    for row in s_cursor:
        subtypes.append(row.getValue(subtypefield))
    subtypes=set(subtypes)
    for i in subtypes:
        do the stuff you need to for each subtype
Getting the list of values and then making them a set will take [a,a,a,b,c,v,v,c,b] and make it [a,b,c,v].
LeeMusto
Chris,
I understand how your script works - I would never have known about the 'Set' function without your reply. I'll give it a try in the near future.
Many thanks for your help.
IanMusto
Lee,
Nothing to do with this particular Python posting, it's just very interesting to find someone with the Musto surname.
If you would like to chat - ian.musto@csiro.au.
Cheers
Ian
PS Sorry to disturb the rest of the thread
