Select by Location in stand alone script
3017
7
12-07-2023 03:44 AM
SoratoSouza_e_Silva
I would like to create stand alone script for do the select by location using two features.
How can I do that?
Using the documentation the error below show:
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000368: Invalid input data.
Failed to execute (SelectLayerByLocation).
Thank´s
Tags (1)
RichardHowe
Select by location operates on feature layers (i.e. objects in an ArcGIS Pro session table of contents). Not on feature classes, which is what you're currently feeding into your script.
If you add a "Make Feature Layer" operation uysing your inputs, then use the outputs of that for your select by location then you should get there.
DanPatterson
MVP Esteemed Contributor
Select Layer By Location (Data Management)—ArcGIS Pro | Documentation
which code sample are you following and what is your script code?
... sort of retired...
SoratoSouza_e_Silva
Follow below my code:
import arcpy
entrada = r"D:\\Profile\\OneDrive - Imagem Geosistemas e Comercio LTDA\\Documentos\\ArcGIS\\Projects\\MyProject10\\MyProject10.gdb\\teste"
recorte = r"D:\\Profile\\OneDrive - Imagem Geosistemas e Comercio LTDA\\Documentos\\ArcGIS\\Projects\\MyProject10\\MyProject10.gdb\\teste1"
saida = r"D:\\Profile\\OneDrive - Imagem Geosistemas e Comercio LTDA\\Documentos\\ArcGIS\\Projects\\MyProject10\\MyProject10.gdb\\teste_saida"
fst = arcpy.SelectLayerByLocation_management(entrada,'intersect', recorte)
arcpy.conversion.ExportFeatures(fst,saida)
No work unfortunately.
Thank´s
DanPatterson
Move your data to a local folder on your computer.  One Drive isn't supported
SoratoSouza_e_Silva
Yes, I understand! I was changed to local folder already, but no work. The same error shows.
RichardHowe
SoratoSouza_e_Silva
Hi!
Solved my problem. Thanks.
RichardHowe
Awesome. Can you mark it as an accepted solution then pls 🙂
