Select by location for the row in a search cursor
13369
01-06-2015 07:46 AM
ThomasCaruso
Hi folks,
I'm trying to use a search cursor to iterate through a table and select the nearest centroids to the feature in the cursor, but when I try this instead of only selecting the centroids nearest the point in the cursor, it instead selects all of the centroids that distance from all of the points, then iterates to the next feature and selects all of them again. Is it possible to make the SelectLayerByLocation_management function only select features based on a single point at a time?
Here's the code I'm using:
# Create search cursor which will iterate through wells, selecting all centroids within a distance
with arcpy.da.SearchCursor(wells, ["OBJECTID"]) as cursor:
        for row in cursor:
                # select by location
                arcpy.SelectLayerByLocation_management("orps09_FL", "WITHIN_A_DISTANCE", wells, "0.5 kilometers", "NEW_SELECTION")
Thanks in advance,
Tom
Tags (1)
JoshuaBixby
MVP Esteemed Contributor
There are a couple or more ways to get this working.  One of the quickest to implement, although it might not be the most peformant, is to include a SelectLayerByAttribute_management statement before the select by location:
    for row in cursor:
        # select by attribute
        SelectLayerByAttribute_management (wells,
                                           "NEW_SELECTION",
                                           "OBJECTID = {}".format(row[0]))
                                               wells,
                                               "0.5 kilometers",
                                               "NEW_SELECTION")
The above assumes that OBJECTID is numeric and not a string.
JoshuaBixby
    for row in cursor:
                                           "NEW_SELECTION",
                                               wells,
                                               "0.5 kilometers",
                                               "NEW_SELECTION")
ThomasCaruso
Hi Joshua,
Thanks for answering. Sadly, this did not actually work for me. I still have the issue of selecting all centroids that distance from all wells - and OBJECTID is indeed numeric. What other ways might I implement this, if you don't mind?
This is the full code I am using. I'm basically trying to compare last names of well owners and nearby centroids to see if there is a match.
import arcpy
arcpy.env.overwriteOutput = 1
# define a workspace
arcpy.env.workspace = r"C:\Users\tmc18\Desktop\comp_orps\NYS_Wells.gdb"
# Define input files
orps09 = r"C:\Users\tmc18\Desktop\comp_orps\centroids\madirps_point1.shp"
wells = r"C:\Users\tmc18\Desktop\comp_orps\NYS_Wells.gdb\Madison_DEC_Well_Logs_3_14_14_MASTER_COPY1"
# Make a feature layer
arcpy.MakeFeatureLayer_management(orps09, "orps09_FL")
arcpy.MakeFeatureLayer_management(wells, "wells1")
wells1 = "wells1"
# Create dictionary of last names of all well owners
well_owners = {}
rows = arcpy.da.SearchCursor(wells1, ["OBJECTID", "owner_last"])
for row in rows:
    well_owners[row[0]] = [row[1]]
del row,rows
with arcpy.da.SearchCursor(wells1, ["OBJECTID"]) as cursor:
        for row in cursor:
            # set well owner name for this record
            owner = well_owners[row[0]]
            arcpy.SelectLayerByAttribute_management(wells1,"NEW_SELECTION","OBJECTID = {}".format(row[0]))
            # Create dictionary of last names of selected orps
            orps_owners = {}
            rows = arcpy.da.SearchCursor("orps09_FL", ["FID", "owner_last"])
            for row in rows:
                orps_owners[row[0]] = [row[1]]
            del row,rows
            # create search cursor which will iterate through selected orps owners
            with arcpy.da.SearchCursor("orps09_FL", ["FID"]) as orpscur:
                for row in orpscur:
                    # set orps owner name
                    orpsowner = orps_owners[row[0]]
                    if owner != orpsowner:
                        print owner, orpsowner
                        continue
                    else:
                        with arcpy.da.UpdateCursor(wells, ["match"]) as cur:
                            for row in cur:
                                row[0] = "YES"
                                cur.updateRow(row)
                            del cur
                            continue
JoshuaBixby
On line 28, try replacing wells with wells1.  The SelectLayerByLocation needs to have the selected feature(s) passed to it and not the original feature class.
ThomasCaruso
ah! Many thanks, my friend. I appreciate your help!
