Select an JSONB column
1083
10-01-2024 09:12 AM
xavierlhomme
Hello
   In a geoprocessing toolbox, I want to select an attribute containing a JSON, with the following code
  sql = f"select jbdata from {table_jsonbdata}"
            tmp = egdb_conn.execute(sql)
but I obtain this error
fail Exception : ArcSDESQLExecute: StreamBindOutputColumn Erreur ArcSDE -65 Invalid pointer argument to function
Exception : File "C:\Users\User01\Desktop\GestionDeProjet\Script-BDD\uploadBackpack.py", line 781, in main
I tried with JSONB : it failed
I tried with TEXT : it failed
I tried with VARCHAR : it failed
I tried with VARCHAR(2048) : it works
How should I store my json in the postgresql table in order to be able to selectit in a geoprocessing script ?
best regards
Xavier Lhomme
GIS Architect / ESIRI Expert
Tags (3)
HaydenWelch
MVP Regular Contributor
According to these docs, JSONB is not supported. VARCHAR(0) and VARCHAR both are read as CLOB type. I'm not sure why it was failing with VARCHAR though as CLOB should be able to store an arbitrary amount of text data.
If you do want to use JSONB, you could try using a different SQL module like sqlalchemy or psychopg2 to pull the data from the PostGIS database in the script, unless you need the whole schema to be fully compatible with Esri apis.
