Searching for values in other tables
3873
8
11-27-2017 03:09 AM
ANNAPRIOR1
I'm relatively new to GIS and Python and am trying to find a way to build a model that will feedback to be whether there is a matching value from one table in another.
In other words, I need to know which (if any) of my values from 'column 1' of 'table 1' appear in 'column 3' of 'table 2'. I know how to do this manually, however there are over 18000 values in 'column 1' of 'table 1' and 28000 in 'column 3' of 'table 2' so automating this will save a lot of time.
Thanks.
BruceHarold
Esri Frequent Contributor
Hi
This tool will let you select values based on shared values in another table view:
http://pm.maps.arcgis.com/home/item.html?id=e638afe0695a4ad38388cb8d9b350446
Regards
XanderBakker
Esri Esteemed Contributor
Can you functionally explain how you would like to see this work. You can easily do this manually and provide this information at table 1 perhaps as an additional field, but you want to use a model (Model Builder?) for this and create a tool that verifies the existence of a selected value of your 'column 1' in 'column 3' of table 2?
If you just want to report which values from table 1 occur in table 2 or which ones don't you should use sets. See some examples here: Some Python Snippets  (scroll down to Compare lists and dictionaries).
Example:
import arcpy
tbl1 = r'your path to table 1'
fld1 = 'column1'
tbl2 = r'your path to table 2'
fld2 = 'column2'
# create a list of the values in table 1, column 1
lst1 = [r[0] for r in arcpy.da.SearchCursor(tbl1, (fld1))]
# create a list of the values in table 2, column 2
lst2 = [r[0] for r in arcpy.da.SearchCursor(tbl2, (fld2))]
# Compare the two lists and get the items in list 1 but not in list 2
lstin1notin2 = list(set(lst1) - set(lst2))
# Compare the two lists and get the items in list 2 but not in list 1
lstin2notin1 = list(set(lst2) - set(lst1))
# Compare two lists and get the items that are in both lists
lstinboth = list(set(lst1) & set(lst2))
This is for comparing two lists, but you cam also check a single value in a list of values:
import arcpy
value1 = 'a value from table 1 column 1'
fld2 = 'column2'
if value1 in lst2:
    print("value 1 is in list 2")
else:
    print("value 1 is not in list 2")
BruceHarold
Hi
Regards
MitchHolley1
What tool are you referring to?  The link is not working for me.
XanderBakker
It is accessible to:
Download contains toolbox and script:
Maybe try https? https://pm.maps.arcgis.com/home/item.html?id=e638afe0695a4ad38388cb8d9b350446
MitchHolley1
Thank you, Xander!
BruceHarold
I think this is the zip payload.
ANNAPRIOR1
Thank you so much! Myself and my colleagues have been tearing our hair out for days trying to work this out and this works perfectly and will honestly save us hours a week.
XanderBakker
Hi ANNA PRIOR , I'm glad you were able to resolve it.
Did you use the toolbox provided by Bruce Harold ? If so, please mark his post as the correct one ("Mark Correct") so that others can find that solution too. If it was another solution please mark the corresponding post as the correct answer.
